19050353
19050353
    CMLTECHNOLOGIES
    INDICATOR PNL MNT 8MM 24V DC SUP
19050353 数据手册
PRODUCT DATA SHEET Part Number: Type LED Part # 1905X353 1905X351 1905X352 1905X357 Size M8 Colour Red Green Yellow Blue Rating 24VDC Voltage(V) 24Vdc 24Vdc 24Vdc 24Vdc 1905X35X Description Recessed Bezel Panel Indicator Current(mA) 20 20 20 20 Intensity(mcd) 80 32 32 60 Notes: 1 2 3 4 5 6 7 8 9 10 11 X = Chrome Bezel finish. 0 = Satin, 1 = Black, 2 = Matt Electrical & optical data are measured at an ambient temperature of 25ºC Luminous intensity at DC Storage temperature -25 ºC to +80ºC Application temperature -20 ºC to +60ºC Voltage tolerance ±10% Due to component tolerances, colour temperature variations may be observed The terminals are not qualified for soldering Degree of protection IP67 when used with the supplied gasket The plastic(polycarbonate) has limited chemical resistance RoHS & REACH SVHC compliant Page 1 of 1 Issue 1 : 24Feb14 CML Innovative Technologies Ltd • 69-70 Eastern Way • Bury St Edmunds • Suffolk • IP32 7AB • England Tel: +44 (0) 1284 714700 • Fax: +44 (0) 1284 724850 • www.cml-it.com Registered Office: Eastern Way, Bury St Edmunds – Registration No. 265006 England
19050353
物料型号:1905X35X
器件简介: - 类型:LED - 尺寸:M8 - 额定值:24VDC - 描述:嵌入式面板指示器
引脚分配: - 引脚1:41 - 引脚2:3 - 引脚3:15 - 引脚4:9 - 引脚5:.60 - 引脚6:2.8x0.8 - 引脚7:SW10 - 引脚8:M8x0,75
参数特性: - 颜色:红、绿、黄、蓝 - 电压:24Vdc - 电流:20mA - 光强度:红80mcd,绿32mcd,黄32mcd,蓝60mcd
功能详解: - 铬色边框完成 - 光色温度变化可能因组件公差而观察到 - 端子未对焊接进行鉴定 - 与所提供的垫圈一起使用时,防护等级为IP67 - 塑料(聚碳酸酯)具有有限的化学抗性
应用信息: - 存储温度:-25°C至+80°C - 应用温度:-20°C至+60°C - 电压容差:±10%
封装信息: - 符合RoHS和REACH SVHC的合规性
19050353 价格&库存
很抱歉,暂时无法提供与“19050353”相匹配的价格&库存,您可以联系我们找货
  • 1+43.10288
  • 10+42.26977
  • 100+39.67672
库存:491
19050353
  • 1+45.66820
  • 10+39.14420
  • 30+34.25120
  • 100+28.84310
  • 500+27.40090
库存:11
