19091M50WE
19091M50WE
    CMLTECHNOLOGIES
    INDICATOR PNL MNT 8MM MULTI VOL
19091M50WE 数据手册
PRODUCT DATA SHEET Part Number: Type LED Size M8 Rating 8 - 32Vdc 1909XM5XWE Description LED Recessed Panel Indicator with leads Dimensions (mm) 185nom +ve -ve 5mm Partial Strip Part # 1909XM50WE 1909XM51WE 1909XM52WE 1909XM57WE Colour Red Green Yellow Blue Current (mA) nom. 2.9 2.9 2.9 2.9 Intensity (mcd) nom. 250 400 140 140 Bezel finish: X = 0 Satin chrome : X = 1 Black chrome : X = 2 Matt chrome Notes: 1 2 3 4 5 6 7 8 9 10 11 12 Electrical & optical data are measured at an ambient temperature of 25ºC LED Luminous intensity without lens Storage temperature -25ºC to +80ºC Application temperature -20ºC to +60ºC Due to component tolerances, slight colour variations may be observed Sealed to IP67 above panel when supplied gasket used The plastic (polycarbonate) has limited chemical resistance Lead wires are internally soldered Lead wires: 7/0.2 stranded copper, tinned annealed copper wire, PVC insulation Marking: Part number, voltage rating and date code This product contains free-machining brass and is RoHS compliant via exemption clause 2011/65/EU Directive Annex III 6 (c) [Copper alloy containing lead (Pb) up to 4% by weight] This product contains lead (Pb) as a constituent of free-machining brass. Lead (Pb) is present in the bezel at less than 4% by weight Page 1 of 1 Issue 2 : 22Nov18 CML Innovative Technologies Ltd • 69-70 Eastern Way • Bury St Edmunds • Suffolk • IP32 7AB • England Tel: +44 (0) 1284 714700 • Fax: +44 (0) 1284 754406 • Email: bury@cml-it.com • www.cml-it.com Registered Office: Eastern Way, Bury St Edmunds – Registration No. 265006 England
19091M50WE 价格&库存
很抱歉,暂时无法提供与“19091M50WE”相匹配的价格&库存,您可以联系我们找货
