SW19STL313
SW19STL313
    CMLTECHNOLOGIES
    SWITCH PB SOLDER TAG ALT ACT PWR
SW19STL313 数据手册
PRODUCT DATA SHEET SW19ST Series Ø19mm stainless steel pushbutton switches Product Configuration SW19 S T    Series Ø19mm Bezel Material S: Stainless steel Terminal T: Solder Tag  Operation Type M: Momentary L: Latching  LED Styling 0: None 1: Dot 2: Ring 3: Power  LED Colour 1: Red 2: Green 3: Yellow 4: Orange 5: Blue 6: White Example Part Numbers SW19STM0 SW19STL253 Momentary, No LED Latching, Ring Styling, Blue LED @ 24V   LED Voltage 1: 6V 2: 12V 3: 24V 4: 36V 5: 110V 6: 240V Specifications Voltage / Current Rating Contact Resistance Insulation Resistance Dielectric Strength Mechanical Life Electrical Life (Full Load) Contact Configuration Soldering 250V / 5A (AC) ≤ 50mΩ ≥ 1,000MΩ 1,780V (AC) ≥ 1,000,000 cycles ≥ 50,000 cycles 1 NC, 1 NO 320°C, < 2 seconds Ingress Protection Impact Rating Operating Force Operating Travel Panel Thickness Range Torque Contact Material Operating Temp. Range IP 65 IK 10 3–5N 3 mm 1 – 10 mm 5 – 14 N Silver alloy -40 to +80°C Contact Configuration / Circuit Diagram + 4 1 2 + _ 2 R _ 3 - - 1 3 4 The LED illumination is polarity insensitive Page 1 of 2 Issue 1: 17Apr19 CML Innovative Technologies Ltd • 69-70 Eastern Way • Bury St Edmunds • Suffolk • IP32 7AB • England Tel: +44 (0) 1284 714700 • Fax: +44 (0) 1284 724850 • www.cml-it.com Registered Office: Eastern Way, Bury St Edmunds – Registration No. 265006 England PRODUCT DATA SHEET SW19ST Series Ø19mm stainless steel pushbutton switches 7.4 + _ 25 M19x1 32 (Momentary) 3 Ø 15.2 1 2 2 4 Ø 22 Outline Dimensions (mm) - Not to scale 7.6 22 38 (Latching) 10.2 7.4 + _ 25 M19x1 32 (Momentary) 3 Ø 15.2 1 2 2 4 Ø 22 Ø 9.2 7.6 22 38 (Latching) 7.4 10.2 7.4 10.2 + _ 25 M19x1 32 (Momentary) 3 Ø 15.2 1 2 2 4 Ø 22 Ø 11.7 7.6 22 38 (Latching) + _ 25 M19x1 22 3 Ø 15.2 1 32 (Momentary) 2 2 4 Ø 22 Ø 11.7 7.6 38 (Latching) Page 2 of 2 Issue 1: 17Apr19 CML Innovative Technologies Ltd • 69-70 Eastern Way • Bury St Edmunds • Suffolk • IP32 7AB • England Tel: +44 (0) 1284 714700 • Fax: +44 (0) 1284 724850 • www.cml-it.com Registered Office: Eastern Way, Bury St Edmunds – Registration No. 265006 England
SW19STL313 价格&库存
很抱歉,暂时无法提供与“SW19STL313”相匹配的价格&库存,您可以联系我们找货
