3239-16-1-0500-006-1-TS 数据手册
P/N 3239-16-1-0500-0XX-1-TS
(Conductor: Tinned strands)
(Insulation: Silicone Rubber)
UL3239 - Silicone Rubber Wire 150°C 3KV (16 AWG)
CONSTRUCTION:
CERTIFICATION & APPROVALS:
Tinned Strands, copper conductor, 26/0.254mm strands.
Overall Diameter = 2.40mm +/-0.15mm
Insulation Thickness: 0.55mm
DUAL-RATED AWM: Can be used in USA and Canada
UL Subject 758 UL FILE NO:E108485
CSA Standard CSA FILE NO:LL84687
Printed Markings:
“AWM 3239 150℃ 3KV E108485-S 18AWG REIHSING CSA I
A 150℃ 3KV LL84687 18AWG FT1 ”
Passes UL VW-1 & CSA FT1 Vertical Flame Test.
PHYSICAL
ELECTRICAL PROPERTIES:
Rated Temperature: 150℃ ~ -50℃
Rated Voltage: 3KV
Insulation Potential Strength: 6000 VAC/min
High flexibility: Soft silicone rubber material.
Maximum Conductor Resistance: 15.6Ω/km
Resistant to: Oil, extremes of hot & cold, flexing, high
Voltage spikes.
APPLICATIONS:
Silicone rubber wire, has high temperature resistance and
high flexibility in confined spaces. Suitable for use in LED
TVs, Laptops, Microwaves, Photocopiers, Scanners.
PACKAGING:
500ft per reel.
ENVIRONMENTAL APPROVALS:
Conforms to all current RoHS directives as laid out in EU
Directive 2011/65/EC
Current SGS reports for this wire are available upon
request.
P/N's & COLORS
3239-16-1-0500-001-1-TS
3239-16-1-0500-002-1-TS
3239-16-1-0500-003-1-TS
3239-16-1-0500-004-1-TS
3239-16-1-0500-005-1-TS
BLACK
WHITE
YELLOW
RED
BLUE
3239-16-1-0500-007-1-TS
3239-16-1-0500-008-1-TS
3239-16-1-0500-010-1-TS
3239-16-1-0500-011-1-TS
BROWN
GREEN
ORANGE
VIOLET
GREEN + YELLOW
3239-16-1-0500-006-1-TS 价格&库存
很抱歉,暂时无法提供与“3239-16-1-0500-006-1-TS”相匹配的价格&库存,您可以联系我们找货
