TP1-330-R
TP1-330-R
    EATON(伊顿)
    SMD,12.2x9.4mm
    33 µH 无屏蔽 环形 电感器 660 mA 684.7 毫欧最大 非标准
TP1-330-R 数据手册
INCORPORATED THIN-PAC THIN-PAC TM GENERAL THIN-PACs are extremely thin, highly efficient surface mount inductors specifically designed for applications where physical size, especially component height, is critical. With heights as low as 1.8 mm, THIN-PACs offer circuit design engineers a choice of very powerful inductors in very small and thin packages. THIN-PACs deliver inductance values from 0.47 to 47.0 µH with current ranges from 0.59 to 2.8 Amps. They are manufactured using toroidal cores for low EMI, high Q, and high efficiency. The devices incorporate advanced technology materials and processes resulting in the highest possible power density in the thinnest possible case. THIN-PACs provide circuit design engineers the highest performance to height ratio of any SMT inductors. Their ideal applications include DC-DC converters, PC cards, disk drives, and small-scale power supplies. THIN-PACs are packaged on standard 13” reels to facilitate pick-and-place assembly. Their rugged construction permits normal exposure to infrared reflow soldering to +240°C. In addition to the standard inductance values shown, modified THIN-PAC inductors are available to meet your high volume requirements. FEATURE - BENEFITS • Ultrathin Product Profile - as Thin as 1.8 mm • Highest Performance to Height Ratio of Any SMT Inductors • Inductance Range from 0.47 to 47.0 µH • Current Range from 0.59 to 2.8 Amps • Toroidal Cores provide Low EMI • High Efficiency and High Q • Supplied in Tape-and-Reel Packaging for Pick-and-Place Assembly • Modified Standard Products Available 1 INCORPORATED Coiltronics designs and manufactures standard and custom electromagnetic components. Contact the factory or your Coiltronics representative with your transformer and inductor requirements. 6000 PARK OF COMMERCE BOULEVARD • BOCA RATON, FL 33487 • Phone 561-241-7876 • Fax 561-241-9339 THIN-PAC TP1-1R0 THIN-PAC 1 FAMILY TABLE (1) OCL µH +/-20% (2) IRMS Amperes (3) (4) ISAT DCR Amperes Ohms max. TP1-R47 0.47 0.544 1.7 3.0 0.1085 *TP1-1R0 1.0 1.17 1.5 2.6 0.1401 TP1-1R5 1.5 1.57 1.4 2.2 0.1560 *TP1-2R2 2.2 2.55 1.3 1.8 0.1876 TP1-3R3 3.3 3.73 1.2 1.5 0.2246 *TP1-4R7 4.7 5.10 1.1 1.3 0.2647 TP1-6R8 6.8 7.45 0.96 1.1 0.3240 *TP1-100 10.0 10.31 0.90 0.92 0.3739 *TP1-150 15.0 16.57 0.81 0.73 0.4612 *TP1-220 22.0 24.25 0.74 0.60 0.5483 *TP1-330 33.0 38.56 0.66 0.47 0.6847 *TP1-470 47.0 49.49 0.62 0.43 0.7699 Notes: m Henries or m Watt-Seconds Inductance µH (rated) 10.0 Typical Inductance & Energy vs Saturation Current 1.0 0.1 0.01 0.0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 2.0 2.2 2.4 2.6 Amperes (Peak) Energy Inductance TP1-100 100.0 (1) Open Circuit Inductance Test Parameters: 100 KHz, 0.250 Vrms, 0.0 Adc. (2) RMS current for an approximate ∆T of 40°C. at an ambient temperature of 85°C. (3) Peak current for approximately 30% rolloff. (4) Values @ 20°C. *BOLD are available from stock m Henries or m Watt-Seconds Part Number TM 10.0 1.0 0.1 Coiltronics Incorporated reserves the right to change component specifications without notice. Typical Inductance & Energy vs Saturation Current 0.0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 Amperes (Peak) MECHANICAL DIAGRAM Inductance TOP VIEW TP1-470 Pin # 1 Indicator. 1 m Henries or m Watt-Seconds CONNECTION DIAGRAM 1 9.40 12.20 max. 9.40 2 2 1.27 SIDE VIEW 100.0 PACKAGING INFORMATION 1.8 max. Typical Inductance & Energy vs Saturation Current 10.0 1.0 0.1 3.18 max. Energy 0.0 0.1 0.2 Parts are packaged on 13” reels. 2250 parts per reel. PCB PAD LAYOUT 0.4 0.5 0.6 0.7 Inductance Energy 2.0 1.5 Dia. 1 0.3 Amperes (Peak) 4.0 Pin #1 Indicator. A 1.75 4.19 11.5 Component View 6.48 14.86 24.0 12.6 9.9 ACTUAL SIZE THIN PAC 1 2.4 2 6.35 INCORPORATED SECTION A-A 3.9 9.9 12.0 A Direction of feed 6000 PARK OF COMMERCE BOULEVARD • BOCA RATON, FL 33487 • Phone 561-241-7876 • Fax 561-241-9339 2 THIN-PAC TM TP2-1R0 Inductance µH (rated) OCL µH +/-20% (2) IRMS Amperes (3) (4) ISAT DCR Amperes Ohms max. TP2-R47 0.47 0.399 2.2 3.2 0.0537 *TP2-1R0 1.0 1.00 1.8 2.1 0.0805 TP2-1R5 1.5 1.53 1.7 1.7 0.0910 *TP2-2R2 2.2 2.15 1.5 1.4 0.1110 TP2-3R3 3.3 3.45 1.4 1.1 0.1328 *TP2-4R7 4.7 4.56 1.3 0.97 0.1472 TP2-6R8 6.8 6.84 1.2 0.80 0.1797 *TP2-100 10.0 9.53 1.1 0.68 0.2151 *TP2-150 15.0 14.83 1.0 0.54 0.2512 *TP2-220 22.0 23.11 0.88 0.44 0.3269 *TP2-330 33.0 32.34 0.67 0.37 0.5677 *TP2-470 47.0 47.68 0.60 0.30 0.6962 Notes: Typical Inductance & Energy vs Saturation Current 10.0 1.0 0.1 0.2 0.0 0.4 0.6 1.4 1.6 1.8 2.0 2.2 Energy Typical Inductance & Energy vs Saturation Current 100.0 (3) Peak current for approximately 30% rolloff. (4) Values @ 20°C. *BOLD are available from stock 10.0 1.0 0.1 0.0 Coiltronics Incorporated reserves the right to change component specifications without notice. 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 Amperes (Peak) MECHANICAL DIAGRAM Energy Inductance TOP VIEW TP2-470 Pin # 1 Indicator. m Henries or m Watt-Seconds Typical Inductance & Energy vs Saturation Current 1 CONNECTION DIAGRAM 1 9.40 6.60 max. 6.60 2 1.27 SIDE VIEW 100.0 10.0 1.0 0.1 0.0 PCB PAD LAYOUT 1.2 TP2-100 (2) RMS current for an approximate ∆T of 40°C. at an ambient temperature of 85°C. 2.51 max. 1.0 Inductance (1) Open Circuit Inductance Test Parameters: 100 KHz, 0.250 Vrms, 0.0 Adc. 2 0.8 Amperes (Peak) m Henries or m Watt-Seconds Part Number (1) m Henries or m Watt-Seconds THIN-PAC 2 FAMILY TABLE 0.1 0.2 0.3 0.4 PACKAGING INFORMATION Amperes (Peak) Parts are packaged on 13” reels. 2000 parts per reel. Inductance 0.5 0.6 Energy 2.2 max. 1.5 Dia. 2.0 Pin #1 Indicator. 1 4.0 A 1.75 4.06 11.5 Component View 3.81 11.93 24.0 9.8 7.1 ACTUAL SIZE THIN PAC 2 2.5 2.9 SECTION A-A 7.1 2 5.08 3 INCORPORATED 12.0 A Direction of feed 6000 PARK OF COMMERCE BOULEVARD • BOCA RATON, FL 33487 • Phone 561-241-7876 • Fax 561-241-9339 THIN-PAC TP3-1R0 THIN-PAC 3 FAMILY TABLE (1) OCL µH +/-20% (2) IRMS Amperes (3) TP3-R47 0.47 0.417 2.6 4.2 0.0644 *TP3-1R0 1.0 1.15 2.1 3.4 0.0949 TP3-1R5 1.5 1.65 2.0 2.8 0.1064 *TP3-2R2 2.2 2.24 1.8 2.4 0.1241 TP3-3R3 3.3 3.68 1.7 1.9 0.1471 *TP3-4R7 4.7 5.45 1.5 1.6 0.1806 TP3-6R8 6.8 7.47 1.4 1.3 0.2051 *TP3-100 10.0 11.09 1.3 1.1 0.2550 *TP3-150 15.0 15.17 1.2 0.97 0.2966 *TP3-220 22.0 23.99 1.1 0.78 0.3700 *TP3-330 33.0 35.08 0.96 0.64 0.4433 *TP3-470 47.0 47.71 0.90 0.55 0.5122 Notes: 10.0 (4) ISAT DCR Amperes Ohms max. m Henries or m Watt-Seconds Inductance µH (rated) Typical Inductance & Energy vs Saturation Current 1.0 0.1 0.0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 2.0 2.2 2.4 2.6 2.8 3.0 3.2 3.4 Amperes (Peak) TP3-100 (1) Open Circuit Inductance Test Parameters: 100 KHz, 0.250 Vrms, 0.0 Adc. (2) RMS current for an approximate ∆T of 40°C. at an ambient temperature of 85°C. (3) Peak current for approximately 30% rolloff. (4) Values @ 20°C. *BOLD are available from stock 100.0 Typical Inductance & Energy vs Saturation Current 10.0 1.0 0.1 Coiltronics Incorporated reserves the right to change component specifications without notice. 0.0 0.1 0.2 0.3 0.4 0.6 0.7 0.8 0.9 1.0 1.1 1.2 1.3 Energy Inductance TOP VIEW TP3-470 Pin #1 Indicator. m Henries or m Watt-Seconds CONNECTION DIAGRAM 1 1 10.80 13.59 max. 10.80 2 1.27 SIDE VIEW 100.0 Typical Inductance & Energy vs Saturation Current 10.0 1.0 0.1 0.0 0.1 0.2 0.3 PACKAGING INFORMATION 3.68 max. 0.5 Amperes (Peak) MECHANICAL DIAGRAM 2 Energy Inductance m Henries or m Watt-Seconds Part Number TM PCB PAD LAYOUT Inductance 2.0 1.5 Dia. Pin # 1 Indicator. 0.5 0.6 0.7 0.8 0.9 Amperes (Peak) Parts are packaged on 13” reels. 1500 parts per reel. 2.2 max. 0.4 A 4.0 Energy 1.75 1 4.19 11.5 Component View 7.87 2 7.40 16.25 24.0 14.0 11.3 ACTUAL SIZE THIN PAC 3 2.5 SECTION A-A 4.1 11.3 16.0 A Direction of feed INCORPORATED 6000 PARK OF COMMERCE BOULEVARD • BOCA RATON, FL 33487 • Phone 561-241-7876 • Fax 561-241-9339 4 THIN-PAC TM TP4-1R0 Inductance µH (rated) (1) OCL µH +/-20% (2) IRMS Amperes (3) (4) ISAT DCR Amperes Ohms max. TP4-R47 0.47 0.507 2.8 6.3 0.0411 *TP4-1R0 1.0 1.09 2.4 4.4 0.0536 TP4-1R5 1.5 1.85 2.2 3.4 0.0641 *TP4-2R2 2.2 2.22 2.1 3.2 0.0715 TP4-3R3 3.3 3.21 2.0 2.7 0.0802 *TP4-4R7 4.7 5.05 1.8 2.2 0.1037 TP4-6R8 6.8 6.54 1.7 1.9 0.1168 *TP4-100 10.0 10.14 1.5 1.6 0.1458 *TP4-150 15.0 14.49 1.4 1.3 0.1727 *TP4-220 22.0 21.33 1.0 1.1 0.3068 *TP4-330 33.0 32.74 0.80 0.87 0.4922 *TP4-470 47.0 47.42 0.59 0.72 0.9080 Notes: 10.0 Typical Inductance & Energy vs Saturation Current 1.0 0.1 0.0 0.0 1.0 0.5 1.5 2.0 2.5 3.0 3.5 4.5 4.0 Amperes (Peak) Energy Inductance TP4-100 m Henries or m Watt-Seconds Part Number m Henries or m Watt-Seconds THIN-PAC 4 FAMILY TABLE (1) Open Circuit Inductance Test Parameters: 100 KHz, 0.250 Vrms, 0.0 Adc. (2) RMS current for an approximate ∆T of 40°C. at an ambient temperature of 85°C. (3) Peak current for approximately 30% rolloff. (4) Values @ 20°C. *BOLD are available from stock 100.0 Typical Inductance & Energy vs Saturation Current 10.0 1.0 0.1 0.0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 1.3 1.4 1.5 1.6 Coiltronics Incorporated reserves the right to change component specifications without notice. Amperes (Peak) MECHANICAL DIAGRAM Energy Inductance TOP VIEW TP4-470 Pin #1 Indicator. 1 9.40 12.20 max. m Henries or m Watt-Seconds CONNECTION DIAGRAM 1 9.40 2 2 1.27 SIDE VIEW 100.0 10.0 1.0 0.1 3.43 max. 3.0 max. 0.2 0.3 0.4 0.5 PACKAGING INFORMATION Amperes (Peak) Inductance 0.6 0.7 Energy 2.0 1.5 Dia. Pin # 1 Indicator. 4.0 4.19 Component View 6.48 0.1 Parts are packaged on 13” reels. 1500 parts per reel. PCB PAD LAYOUT 1 Typical Inductance & Energy vs Saturation Current A 1.75 11.5 14.86 24.0 12.6 9.9 ACTUAL SIZE THIN PAC 4 3.3 2 6.86 3.9 SECTION A-A 9.9 12.0 A Direction of feed 5 INCORPORATED 6000 PARK OF COMMERCE BOULEVARD • BOCA RATON, FL 33487 • Phone 561-241-7876 • Fax 561-241-9339 THIN-PAC TM ENVIRONMENTAL SPECIFICATIONS DESIGN KITS AVAILABLE • Storage Temperature Range: -40°C to +125°C. • Operating Ambient Temperature Range: -40°C to +85°C Range is application specific • Infrared Reflow Temperature: +240°C for 30 seconds maximum • Meets UL 94V-O Flammability Standard To assist in prototyping, Coiltronics offers low-cost Design Kits for the THIN-PAC product family. Each Kit contains an assortment of inductance values complete with specifications. Coiltronics Design Kits can save hours (even days) of searching for parts and waiting on samples. • Order Part Number TPK01-13692 Information furnished herein by Coiltronics Incorporated is believed to be accurate and reliable. However, Coiltronics Incorporated cannot assume responsibility for the use of any of our components, nor for any liabilities which may result from component use. Coiltronics Incorporated reserves the right to change component specifications without notice. Life Support Policy: Coiltronics Incorporated does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of Coiltronics Incorporated. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. ©1997 Coiltronics Incorporated. All rights reserved. INCORPORATED Distributed by BRAVO ELECTRO COMPONENTS, INC. • Phone 800-392-6318 • Fax 408-783-8555 6
TP1-330-R 价格&库存
很抱歉,暂时无法提供与“TP1-330-R”相匹配的价格&库存,您可以联系我们找货
