SD20C-331-R
SD20C-331-R
    EATON(伊顿)
    SMD,5.2x5.2mm
    330 µH 屏蔽 绕线 电感器 294 mA 2.99 欧姆 非标准
SD20C-331-R 数据手册
CUSTOMER INFORMATION 2.0mm Shielded Drum Core (SD20C) Family Table Part Number Rated Inductance (µH) OCL nominal +/-20% (µH) SD20C-R47 0.47 0.490 SD20C-1R2 1.20 1.21 SD20C-1R5 1.50 1.69 SD20C-2R2 2.20 2.25 SD20C-3R3 3.30 3.61 SD20C-4R7 4.70 4.41 SD20C-6R2 6.20 6.25 SD20C-8R2 8.20 8.41 SD20C-100 10.0 9.61 SD20C-150 15.0 15.21 SD20C-220 22.0 22.09 SD20C-330 33.0 32.49 SD20C-470 47.0 47.61 SD20C-680 68.0 68.89 SD20C-820 82.0 82.81 SD20C-101 100 98.01 SD20C-151 150 151.3 SD20C-221 220 222.0 SD20C-331 330 327.6 SD20C-471 470 470.9 SD20C-681 680 681.2 SD20C-821 820 823.7 SD20C-102 1000 1004.9 Electrical Requirement Notes: 1) Test Parameters: 100KHz, 0.25Vrms Part Marking Designator A B C D E F G H J K L M N O P Q R S T U V W X 2) DCR @ 20°C IRMS Amperes for approximately a ∆T of 40°C. above 85°C ambient 3.59 3.07 2.88 2.45 2.17 2.05 1.89 1.61 1.53 1.25 1.12 0.913 0.745 0.610 0.576 0.495 0.435 0.356 0.294 0.263 0.216 0.204 0.172 ISAT Amperes Peak for approximately 30% rolloff (@ 20°C). DCR (Ω) typ. @ 20°C. 4.00 2.55 2.15 1.87 1.47 1.33 1.12 0.966 0.903 0.718 0.596 0.491 0.406 0.337 0.308 0.283 0.228 0.188 0.155 0.129 0.107 0.098 0.088 0.0200 0.0275 0.0312 0.0429 0.0547 0.0612 0.0720 0.1000 0.1100 0.1655 0.2053 0.3100 0.4650 0.6947 0.7785 1.06 1.37 2.04 2.99 3.74 5.56 6.22 8.73 Part number definition: First 4 characters = Product code and size. Last 3 characters = Inductance in µH. R=decimal point. If no R is present third character = # of zeros. (1) Units supplied in tape and reel packaging. 13" reels 2900 parts per reel. Meets EIA-481 standard Cooper Electronic Technologies 1225 Broken Sound Pkwy NW Suite F Boca Raton, FL 33487 Shielded Drum Core, (SD20C) SMT Inductor Line 2.0 mm height. Electrical Specifications Option Code (Suffix) -R Description RoHS Compliant Version SIZE Drawing Number: A Revision Level: SD20C-R Inductor Line B Sheet 4 of 29
SD20C-331-R 价格&库存
很抱歉,暂时无法提供与“SD20C-331-R”相匹配的价格&库存,您可以联系我们找货
