UP0.4SC-6R8-R
UP0.4SC-6R8-R
    EATON(伊顿)
    SMD,6.6x4.5mm
    6.8 µH 屏蔽 绕线 电感器 1.2 A 65 毫欧最大 非标准
UP0.4SC-6R8-R 数据手册
CUSTOMER INFORMATION Part Number Rated OCL nominal (µH) Inductance @20°C (µH) UP0.4SC-1R0 1.0 1.0+/-20% UP0.4SC-1R5 1.5 1.5 +/-20% UP0.4SC-2R2 2.2 2.2+/-20% UP0.4SC-3R3 3.3 3.3+/-20% UP0.4SC-4R7 4.7 4.7+/-20% UP0.4SC-6R8 6.8 6.8+/-20% UP0.4SC-100 10.0 10.0+/-20% UP0.4SC-150 15.0 15.0+/-20% UP0.4SC-220 22.0 22.0+/-20% UP0.4SC-330 33.0 33.0+/-20% UP0.4SC-470 47.0 47.0+/-20% UP0.4SC-680 68.0 68.0+/-20% UP0.4SC-101 100 100+/-20% UP0.4SC-151 150 150+/-20% UP0.4SC-221 220 220+/-20% UP0.4SC-331 330 330+/-20% UP0.4SC-471 470 470+/-20% UP0.4SC-681 680 680+/-20% UP0.4SC-102 1000 1000+/-20% UP0.4SC-152 1500 1500+/-20% UP0.4SC-222 2200 2200+/-20% UP0.4SC-332 3300 3300+/-20% UP0.4SC-472 4700 4700+/-20% UP0.4SC-682 6800 6800+/-20% UP0.4SC-103 10000 10000+/-20% Electrical Requirement Notes: 1) Test Frequency: 100KHz, 0.1V Irms (max) (a) 3.0 2.8 1.8 1.6 1.4 1.2 1.0 0.80 0.70 0.60 0.50 0.40 0.30 0.26 0.22 0.20 0.19 0.18 0.15 0.12 0.10 0.08 0.06 0.04 0.02 2) DCR @ 20°C Q min 30 @ 200kHz 30 @ 200kHz 40 @ 200kHz 40 @ 200kHz 40 @ 200kHz 40 @ 200kHz 40 @ 200kHz 40 @ 200kHz 40 @ 100kHz 40 @ 100kHz 40 @ 100kHz 40 @ 100kHz 40 @ 100kHz 40 @ 100kHz 40 @ 100kHz 40 @ 100kHz 40 @ 100kHz 40 @ 100kHz 40 @ 100kHz 50 @ 100kHz 50 @ 100kHz 50 @ 100kHz 50 @ 100kHz 50 @ 100kHz 50 @ 100kHz SRF typ (MHz) DCR (Ω) max @ 20°C. .040 .045 .050 .055 .060 .065 .075 .090 .110 .190 .230 .290 .480 .590 .770 1.4 1.8 2.2 3.4 4.2 8.5 11.0 13.9 25.0 32.8 250 125 120 120 105 50 38 33 25 20 20 15 10 9 6 5 4 3 2 2 2 1 1 1 .08 This Document Is Subject To Change Without Notice. General Specifications: a) Temp. Rise: 30°C typ at Irms b) Operating Temp: -40°C -- +125°C c) Storage Temp.: -25°C~+125°C d) Resistance to Solder Heat: 260°C for 10 secs. Parts available in Tape and Reel. 13” diameter reel : 2,500 parts per reel. Option Code (Suffix) -R Description ROHS compliant Version Cooper Electronic Technologies 3601 Quantum Blvd, Boynton Beach, FL 33426 Unipac 0.4SC (UP0.4SC) Inductor Line SMD, 2.92mm max ht, Shielded Drum core/header SIZE Drawing Number: A Revision Level: B UP0.4SC-R Inductor Line Sheet 2 of 4
UP0.4SC-6R8-R 价格&库存
很抱歉,暂时无法提供与“UP0.4SC-6R8-R”相匹配的价格&库存,您可以联系我们找货
