UP0.4UC-1R5-R
UP0.4UC-1R5-R
    EATON(伊顿)
    非标准
    1.5 µH 无屏蔽 绕线 电感器 2.8 A 50 毫欧最大 非标准
UP0.4UC-1R5-R 数据手册
A Revision Level: B Sheet 1 of 4 CUSTOMER INFORMATION Part Number Rated Inductance (µH) OCL nominal (µH) @20°C UP0.4UC-1R0 UP0.4UC-1R5 UP0.4UC-2R2 UP0.4UC-3R3 UP0.4UC-4R7 UP0.4UC-6R8 UP0.4UC-100 UP0.4UC-150 UP0.4UC-220 UP0.4UC-330 UP0.4UC-470 UP0.4UC-680 UP0.4UC-101 UP0.4UC-151 UP0.4UC-221 UP0.4UC-331 UP0.4UC-471 UP0.4UC-681 UP0.4UC-102 1.0 1.5 2.2 3.3 4.7 6.8 10.0 15.0 22.0 33.0 47.0 68.0 100 150 220 330 470 680 1000 1.0+/-20% 1.5 +/-20% 2.2+/-20% 3.3+/-20% 4.7+/-20% 6.8+/-20% 10.0+/-20% 15.0+/-20% 22.0+/-20% 33.0+/-20% 47.0+/-20% 68.0+/-20% 100+/-20% 150+/-20% 220+/-20% 330+/-20% 470+/-20% 680+/-20% 1000+/-20% Electrical Requirement Notes: 1) Test Frequency: 100KHz,0.1V IRMS Amperes for approximately a ∆T of 30°C. above 85°C ambient 2.9 2.8 2.4 2.0 1.5 1.4 1.1 1.0 0.80 0.60 0.50 0.40 0.30 0.25 0.20 0.16 0.15 0.12 0.07 ISAT Amperes Peak for approximately 10 % rolloff (@ 20°C). DCR milli-(Ω) max @ 20°C. SRF typ (MHz) 2.9 2.6 2.3 2.0 1.5 1.2 1.1 0.9 0.7 0.58 0.5 0.4 0.31 0.27 0.22 0.18 016 0.14 0.10 50.0 50.0 70.0 80.0 90.0 130 160 230 370 510 640 860 1270 2000 3110 3800 5060 9200 13800 130 115 90 70 50 45 35 30 20 15 14 11 9 6 5.5 5 4 3 2 2) DCR @ 20°C This Document Is Subject To Change Without Notice. General Specifications: a) Temp. Rise: 30°C typ at Irms b) Inductance drop is approx. 10% at Isat. c) Operating Ambient Temp: -25°C ~ +85°C d) Storage Temp.: -40°C ~ +125°C e) Resistance to Solder Heat: 260°C for 10 secs. Parts available in Tape and Reel. 13” diameter reel : 2,500 parts per reel. Option Code (Suffix) Description Cooper Electronic Technologies 3601 Quantum Blvd, Boynton Beach, FL 33426 Unipac 0.4UC (UP0.4UC) Inductor Line SMD, 2.92mm max ht, Drum core/header SIZE Drawing Number: UP0.4UC-R Inductor Line
UP0.4UC-1R5-R
- 物料型号:UP0.4UC系列,包括UP0.4UC-1R0至UP0.4UC-102等多种型号。 - 器件简介:UP0.4UC系列是SMD电感器,最大高度为2.92mm,采用鼓形芯/头。 - 引脚分配:文档中未明确提供引脚分配信息,但通常SMD电感器有端点和接地点。 - 参数特性:包括额定电感值、OCL标称值、IRMS电流、Isat峰值电流、DCR最大值和SRF典型值。 - 功能详解:文档提供了电感器的电气要求,如测试频率、DCR测试条件、温度上升、电感下降、工作环境温度、存储温度和耐焊热性。 - 应用信息:适用于需要电感器的电子设备,具体应用场景未在文档中详述。 - 封装信息:提供Tape and Reel封装,每卷2500个部件,直径13英寸。
UP0.4UC-1R5-R 价格&库存
很抱歉,暂时无法提供与“UP0.4UC-1R5-R”相匹配的价格&库存,您可以联系我们找货
