17000174A
17000174A
    COMAIRROTRON
    FAN 80X15.5MM CR0824LB-D90(T)
17000174A 数据手册
SPECIFICATIONS “Preliminary data” Model Number: Part Number: CR0824LB-D90(T) 17000174A Version: Apr 11, 2017 Mechanical Drawing: Motor: Nominal Voltage Nominal Running Current Power Input Speed Bearings Air Flow Static Pressure: Acoustic Weight = 24 VDC = 0.05 Amps = 1.20 Watts = 3000 RPM = Ball = 29.58 CFM = 0.12 Inch of H2O = 36 dB(A) = 63.0 g Construction: Housing: UL94V-0 Glass Filled Polyester (P.B.T) Impeller: UL94V-0 Glass Filled Polyester (P.B.T) Life Expectancy: This fan is designed for continuous duty life of 70,000 hours at 40°C. Additional Features: Brushless DC Motor Locked Rotor Protection Polarity Protected Automatic Restart Capability Operating Temperature: Storage Temperature: -10ºC to 70ºC -40ºC to 70ºC Termination: 300±10 mm Lead wires, AWG 24, UL 1007 Agency Approvals: UL, CUL, TUV, CE
17000174A 价格&库存
很抱歉,暂时无法提供与“17000174A”相匹配的价格&库存,您可以联系我们找货
