17000176A
17000176A
    COMAIRROTRON
    FAN AXIAL 40X15MM CR0412HB-D51
17000176A 数据手册
SPECIFICATIONS “Preliminary data” Model Number: Part Number: CR0412HB-D51 17000176A Version: Apr 11, 2017 Mechanical Drawing: Motor: Nominal Voltage Nominal Running Current Power Input Speed Bearings Air Flow Static Pressure: Acoustic Weight = 12 VDC = 0.11 Amps = 1.32 Watts = 8000 RPM = Ball = 8.48 CFM = 0.25 Inch of H2O = 36.0 dB(A) = 27.0 g Construction: Housing: UL94V-0 Glass Filled Polyester (P.B.T) Impeller: UL94V-0 Glass Filled Polyester (P.B.T) Life Expectancy: This fan is designed for continuous duty life of 70,000 hours at 40°C. Additional Features: Brushless DC Motor Locked Rotor Protection Polarity Protected Automatic Restart Capability Operating Temperature: Storage Temperature: -10ºC to 70ºC -40ºC to 70ºC Termination: 295±10 mm Lead wires, AWG 26, UL 1007 Agency Approvals: UL, CUL, TUV, CE
17000176A 价格&库存
很抱歉,暂时无法提供与“17000176A”相匹配的价格&库存,您可以联系我们找货
