17000182A
17000182A
    COMAIRROTRON
    FAN 50X10.5 CR0505HB-G70(T) 5VDC
17000182A 数据手册
SPECIFICATIONS “Preliminary data” Model Number: Part Number: CR0505HB-G70(T) 17000182A Version: Apr 11, 2017 Mechanical Drawing: Motor: Nominal Voltage Nominal Running Current Power Input Speed Bearings Air Flow Static Pressure: Acoustic Weight = 5 VDC = 0.22 Amps = 1.10 Watts = 5000 RPM = Ball = 10.3 CFM = 0.10 Inch of H2O = 27.5 dB(A) = 18.0 g Construction: Housing: UL94V-0 Glass Filled Polyester (P.B.T) Impeller: UL94V-0 Glass Filled Polyester (P.B.T) Life Expectancy: This fan is designed for continuous duty life of 70,000 hours at 40°C. Additional Features: Brushless DC Motor Locked Rotor Protection Polarity Protected Automatic Restart Capability Operating Temperature: Storage Temperature: -10ºC to 70ºC -40ºC to 70ºC Termination: 290±10 mm Lead wires, AWG 26, UL 1007 Agency Approvals: UL, CUL, TUV, CE
17000182A 价格&库存
很抱歉,暂时无法提供与“17000182A”相匹配的价格&库存,您可以联系我们找货
