17000186A
17000186A
    COMAIRROTRON
    FAN 60X15MM CR0612HB-GA0(GLT1)
17000186A 数据手册
SPECIFICATIONS Model Number: Part Number: “Preliminary data” CR0612HB-GA0(GLT1) 17000186A Version: Apr 11, 2017 Mechanical Drawing: Motor: Nominal Voltage Nominal Running Current Power Input Speed Bearings Air Flow Static Pressure: Acoustic Weight = 12 VDC = 0.25 Amps = 3.00 Watts = 4600 RPM = Ball = 21.37 CFM = 0.14 Inch of H2O = 35.8 dB(A) = 30.0 g Construction: Housing: UL94V-0 Glass Filled Polyester (P.B.T) Impeller: UL94V-0 Glass Filled Polyester (P.B.T) Life Expectancy: This fan is designed for continuous duty life of 70,000 hours at 40°C. Additional Features: Brushless DC Motor Locked Rotor Protection Polarity Protected Automatic Restart Capability Operating Temperature: Storage Temperature: -10ºC to 70ºC -40ºC to 70ºC Termination: 130±10 mm Lead wires, AWG 26, UL 1007 Agency Approvals: UL, CUL, TUV, CE
17000186A 价格&库存
很抱歉,暂时无法提供与“17000186A”相匹配的价格&库存,您可以联系我们找货
