17000196A
17000196A
    COMAIRROTRON
    FAN AXL 25X10MM CR0212DB-G50(GL)
17000196A 数据手册
SPECIFICATIONS Model Number: Part Number: “Preliminary data” CR0212DB-G50(GL) 17000196A Version: Apr 11, 2017 Mechanical Drawing: Motor: Nominal Voltage Nominal Running Current Power Input Speed Bearings Air Flow Static Pressure: Acoustic Weight = 12 VDC = 0.04 Amps = 0.48 Watts = 6000 RPM = Ball = 1.1 CFM = 0.04 Inch of H2O = 12.5 dB(A) = 8.0 g Construction: Housing: UL94V-0 Glass Filled Polyester (P.B.T) Impeller: UL94V-0 Glass Filled Polyester (P.B.T) Life Expectancy: This fan is designed for continuous duty life of 70,000 hours at 40°C. Additional Features: Brushless DC Motor Locked Rotor Protection Polarity Protected Automatic Restart Capability Operating Temperature: Storage Temperature: -10ºC to 70ºC -40ºC to 70ºC Termination: 140±10 mm Lead wires, AWG 28, UL 1571 Agency Approvals: UL, CUL, TUV, CE
17000196A 价格&库存
很抱歉,暂时无法提供与“17000196A”相匹配的价格&库存,您可以联系我们找货
