17000201A
17000201A
    COMAIRROTRON
    CR3505DB-G50(T)
17000201A 数据手册
SPECIFICATIONS “Preliminary data” Model Number: Part Number: CR3505DB-G50(T) 17000201A Version: Apr 11, 2017 Mechanical Drawing: Motor: Nominal Voltage Nominal Running Current Power Input Speed Bearings Air Flow Static Pressure: Acoustic Weight = 5 VDC = 0.04 Amps = 0.21 Watts = 4500 RPM = Ball = 3.0 CFM = 0.05 Inch of H2O = 17.0 dB(A) = 9.0 g Construction: Housing: UL94V-0 Glass Filled Polyester (P.B.T) Impeller: UL94V-0 Glass Filled Polyester (P.B.T) Life Expectancy: This fan is designed for continuous duty life of 70,000 hours at 40°C. Additional Features: Brushless DC Motor Locked Rotor Protection Polarity Protected Automatic Restart Capability Operating Temperature: Storage Temperature: -10ºC to 70ºC -40ºC to 70ºC Termination: 140±10 mm Lead wires, AWG 28, UL 1571 Agency Approvals: UL, CUL, TUV, CE
17000201A 价格&库存
很抱歉,暂时无法提供与“17000201A”相匹配的价格&库存,您可以联系我们找货
