17000203A
17000203A
    COMAIRROTRON
    CR3512MB-G50-ALARM SENSOR
17000203A 数据手册
SPECIFICATIONS “Preliminary data” Model Number: Part Number: CR3512MB-G50 17000203A Version: Apr 11, 2017 Mechanical Drawing: Motor: Nominal Voltage Nominal Running Current Power Input Speed Bearings Air Flow Static Pressure: Acoustic Weight = 12 VDC = 0.06 Amps = 0.66 Watts = 8000 RPM = Ball = 6.0 CFM = 0.17 Inch of H2O = 32.0 dB(A) = 9.0 g Construction: Housing: UL94V-0 Glass Filled Polyester (P.B.T) Impeller: UL94V-0 Glass Filled Polyester (P.B.T) Life Expectancy: This fan is designed for continuous duty life of 70,000 hours at 40°C. Additional Features: Brushless DC Motor Locked Rotor Protection Polarity Protected Automatic Restart Capability Operating Temperature: Storage Temperature: -10ºC to 70ºC -40ºC to 70ºC Termination: 140±10 mm Lead wires, AWG 28, UL 1571 Agency Approvals: UL, CUL, TUV, CE
17000203A 价格&库存
很抱歉,暂时无法提供与“17000203A”相匹配的价格&库存,您可以联系我们找货
