17000298A
17000298A
    COMAIRROTRON
    风扇 管轴式 24VDC 圆形 - 254mm 直径 滚珠 550.0 CFM(15.40m³/min) 3 引线
17000298A 数据手册
SPECIFICATIONS Model Number: Part Number: CD24B7 17000298A Version: 00 Nov. 09, 2015 Mechanical Drawing: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Air Flow Noise Additional Features: = 24 vdc = 12 - 28 vdc = 1.20 amps = 3.00 amps = 29.0 watts = 1650 rpm = Ball = 550 cfm = 49.1dBA Brushless DC Motor Polarity Protected Locked Rotor Protection Automatic Restart Capability Operating Temperature: Storage Temperature: -10°C to 70°C -40°C to 85°C Tachometer Specifications: Venturi: Die-Cast Aluminum, Black Propeller: Plastic, Black, UL 94V-0 5 volt TTL Compatible Ic: 5 vdc Typical Pulses Per Revolution: 2 Isolated: No Life Expectancy: Termination: Construction: This fan is designed for continuous duty life of 60,000 hours at 40°C. Agency Approvals: UL, CUR, CE Output: 12” Lead wires, 22 AWG, UL 1061 Red = Power (+) Black = Return (-) Blue/White = Tach (Output)
17000298A 价格&库存
很抱歉,暂时无法提供与“17000298A”相匹配的价格&库存,您可以联系我们找货
17000298A
    库存:100
    17000298A
    • 1+704.554121+91.21063
    库存:9
