17000299A
17000299A
    COMAIRROTRON
    FAN AXIAL 175.5X107.2MM TD48B7
17000299A 数据手册
SPECIFICATIONS Model Number: Part Number: TD48B7 17000299A Version: 00 Nov. 09, 2015 Mechanical Drawing: Motor: Nominal Voltage Operating Voltage Range Locked Rotor Current Nominal Running Current Running Power Average Speed Bearings Air Flow Noise = 48 vdc = 24– 56 vdc = 1.5 amps = 0.700 amps = 33.6 watts = 3275 rpm = Ball = 155 cfm = 65.2 dBA Construction: Venturi: Plastic, Black, UL94V-0 Propeller: Plastic, Black, UL94V-0 Life Expectancy: This fan is designed for continuous duty life of 35,000 hours at 40°C Agency Approvals: UL, CUR, CE Additional Features: Brushless DC Motor Polarity Protected Locked Rotor Protection Automatic Restart Capability Operating Temperature: Storage Temperature: -10°C to +70°C -40°C to +85°C Tachometer: Output: Ic: Isolated: Pulses per Rev.: 5 volt TTL 5 mA Max. No 2 Termination: 12” Lead-wires, AWG 22, UL 1061 Red = Power (+) Black = Return (-) Blue/White = Tachometer (Output)
17000299A 价格&库存
很抱歉,暂时无法提供与“17000299A”相匹配的价格&库存,您可以联系我们找货
