17001133A
17001133A
    COMAIRROTRON
    FAN DC IP68 STD24K3E2X-E3
17001133A 数据手册
SPECIFICATIONS (RoHS Compliant) Model Number: Part Number: STD24K3E2X-E3 17001133A Version: 00 Jun 12, 2018 Mechanical Drawing: Additional Features: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Max. Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic = 24 vdc = 16-32 vdc = 0.190 amps = 0.65 amps = 4.5 watts = 4200 RPM = Ball = 38 CFM = 44.2 dBA Brushless DC Motor Automatic Restart Capability Electronic Locked Rotor Protection Polarity Protected Operating Temperature: -10C to 70C Storage Temperature: -40C to 85C Environmental Protection: Type 3(IP68) TACHOMETER: Life Expectancy: Output: Open Collector Ic: 20 mA max. Vcc: 32 Vdc max. Pulses per Revolution: 2 Isolated: No This fan is designed for continuous duty life of 45,000 hours at 70C. Speed Control: Construction: Venturi: Plastic, Black, UL 94V-0 Propeller: Plastic, Black, UL 94V-0 Termination: 12”±1”(304.8±25.4mm) 22AWG UL1061 Leadwires Red = Power(+) Black = Return(-) Blue/White = Tach output Yellow = PWM control PWM: 200 ~ 2 KHz, Open Collector 95% Duty or Open Lead Wire: Full Speed Agencies: UL, CUL, CE PQ Curve:
17001133A 价格&库存
很抱歉,暂时无法提供与“17001133A”相匹配的价格&库存,您可以联系我们找货
17001133A
  • 300+319.62776300+41.25763
