17001135A
17001135A
    COMAIRROTRON
    FAN DC IP68 STD12Z3E2X-E3
17001135A 数据手册
SPECIFICATIONS (RoHS Compliant) Model Number: Part Number: STD12Z3E2X-E3 17001135A Version: 00 Jun 12, 2018 Mechanical Drawing: Additional Features: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Max. Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic = 12 vdc = 8-16 vdc = 0.520 amps = 2.100 amps = 6.2 watts = 4700 RPM = Ball = 45 CFM = 51.5 dBA Brushless DC Motor Automatic Restart Capability Electronic Locked Rotor Protection Polarity Protected Operating Temperature: -10C to 70C Storage Temperature: -40C to 85C Environmental Protection: Type 3(IP68) TACHOMETER: Life Expectancy: Output: Open Collector Ic: 20 mA max. Vcc: 32 Vdc max. Pulses per Revolution: 2 Isolated: No This fan is designed for continuous duty life of 45,000 hours at 70C. Speed Control: Construction: Venturi: Plastic, Black, UL 94V-0 Propeller: Plastic, Black, UL 94V-0 Termination: 12”±1”(304.8±25.4mm) 22AWG UL1061 Leadwires Red = Power(+) Black = Return(-) Blue/White = Tach output Yellow = PWM control PWM: 200 ~ 2 KHz, Open Collector 95% Duty or Open Lead Wire: Full Speed Agencies: UL, CUL, CE PQ Curve:
17001135A
- 物料型号:STD12Z3E2X-E3,部件编号:17001135A - 器件简介:COMAIR ROTRON,一种直流风扇,具有多种特性和规格。 - 引脚分配:12英寸(304.8±25.4mm)的22AWG UL1061引线,颜色编码为红色(电源正)、黑色(返回负)、蓝/白(转速输出)、黄色(PWM控制)。 - 参数特性:额定电压8-16VDC,额定运行电流0.520A,最大功率6.2W,转速4700RPM,风量45CFM,噪音51.5dBA。 - 功能详解:包括PWM控制、自动重启能力、电子锁定转子保护和极性保护。 - 应用信息:适用于需要连续运行的应用,设计寿命为45,000小时,存储温度范围-40°C至85°C。 - 封装信息:Venturi和Propeller均为黑色塑料材质,符合UL 94V-0标准。 - 认证机构:UL, CUL, CE。 - 性能曲线图提供了风量(CFM)与静压(mmH2O)的关系。
17001135A 价格&库存
很抱歉,暂时无法提供与“17001135A”相匹配的价格&库存,您可以联系我们找货
17001135A
  • 300+319.62776300+41.25763
