17001139A
17001139A
    COMAIRROTRON
    风扇 管轴式 24VDC 方形 - 79.8mm 长 x 79.8mm 高 滚珠 35.0 CFM(0.980m³/min) 4 引线
17001139A 数据手册
SPECIFICATIONS (RoHS Compliant) Model Number: Part Number: SDD24B1E2X-E3 17001139A Version: 00 Jun 12, 2018 Mechanical Drawing: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic Additional Features: = 24 vdc = 16 – 32vdc = 0.130 amps = 0.6 amps = 3.0 watts = 3500 = Ball = 35 CFM = 47.6 dBA Brushless DC Motor Automatic Restart Capability Electronic Locked Rotor Protection Polarity Protected Operating Temperature: -10C to 70C Storage Temperature: -40C to 85C Environmental Protection: Type 3(IP68) TACHOMETER: Life Expectancy: Output: Open Collector Ic: 20 mA max. Vcc: 32 Vdc max. Pulses per Revolution: 2 Isolated: No This fan is designed for continuous duty life of 52,000 hours at 70C. Speed Control: Construction: Venturi: Single Piece Die-Cast Zinc Alloy, Black Propeller: Plastic, Black, UL 94V-0 Termination: 12”±1”(304.8±25.4mm) 22AWG UL1061 Leadwires Red = Power(+) Black = Return(-) Blue/White = Tach output Yellow = PWM control PWM: 200 ~ 2 KHz, Open Collector 95% Duty or Open Lead Wire: Full Speed Agencies: UL, CUL, CE PQ Curve:
17001139A 价格&库存
很抱歉,暂时无法提供与“17001139A”相匹配的价格&库存,您可以联系我们找货
17001139A
  • 1+528.494781+68.30753
库存:1
