SPECIFICATIONS
(RoHS Compliant)
Model Number:
Part Number:
SDD12K1E2X-E3
17001141A
Version: 00
Jun 12, 2018
Mechanical Drawing:
Motor:
Nominal Voltage
Operating Voltage Range
Nominal Running Current
Locked Rotor Current
Running Power
Average Speed
Bearings
Air Flow
Acoustic
Additional Features:
= 12 vdc
= 8 – 16vdc
= 0.430 amps
= 1.00 amps
= 5.2 watts
= 4200
= Ball
= 43 CFM
= 52.1 dBA
Brushless DC Motor
Automatic Restart Capability
Electronic Locked Rotor Protection
Polarity Protected
Operating Temperature:
-10C to 70C
Storage Temperature:
-40C to 85C
Environmental Protection:
Type 3(IP68)
TACHOMETER:
Life Expectancy:
Output: Open Collector
Ic: 20 mA max.
Vcc: 32 Vdc max.
Pulses per Revolution: 2
Isolated: No
This fan is designed for continuous duty life of 52,000 hours
at 70C.
Speed Control:
Construction:
Venturi: Single Piece Die-Cast Zinc Alloy, Black
Propeller: Plastic, Black, UL 94V-0
Termination:
12”±1”(304.8±25.4mm) 22AWG UL1061 Leadwires
Red = Power(+)
Black = Return(-)
Blue/White = Tach output
Yellow = PWM control
PWM: 200 ~ 2 KHz, Open Collector
95% Duty or Open Lead Wire: Full Speed
Agencies:
UL, CUL, CE
PQ Curve:
很抱歉,暂时无法提供与“17001141A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 300+428.93203300+55.59776
