17001143A
17001143A
    COMAIRROTRON
    FAN DC IP68 SDD48K1E2X-E3
17001143A 数据手册
SPECIFICATIONS (RoHS Compliant) Model Number: Part Number: SDD48K1E2X-E3 17001143A Version: 00 Jun 12, 2018 Mechanical Drawing: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic Additional Features: = 48 vdc = 36 – 60vdc = 0.110 amps = 0.50 amps = 5.2 watts = 4200 = Ball = 43 CFM = 52.1 dBA Brushless DC Motor Automatic Restart Capability Electronic Locked Rotor Protection Polarity Protected Operating Temperature: -10C to 70C Storage Temperature: -40C to 85C Environmental Protection: Type 3(IP68) TACHOMETER: Life Expectancy: Output: Open Collector Ic: 20 mA max. Vcc: 60 Vdc max. Pulses per Revolution: 2 Isolated: No This fan is designed for continuous duty life of 52,000 hours at 70C. Speed Control: Construction: Venturi: Single Piece Die-Cast Zinc Alloy, Black Propeller: Plastic, Black, UL 94V-0 Termination: 12”±1”(304.8±25.4mm) 22AWG UL1061 Leadwires Red = Power(+) Black = Return(-) Blue/White = Tach output Yellow = PWM control PWM: 200 ~ 2 KHz, Open Collector 95% Duty or Open Lead Wire: Full Speed Agencies: UL, CUL, CE PQ Curve:
17001143A 价格&库存
很抱歉,暂时无法提供与“17001143A”相匹配的价格&库存,您可以联系我们找货
