17001157A
17001157A
    COMAIRROTRON
    风扇 管轴式 24VDC 方形 - 120mm 长 x 120mm 高 滚珠 110.0 CFM(3.08m³/min) 4 引线
17001157A 数据手册
SPECIFICATIONS Model Number: Part Number: (RoHS Compliant) MSD24B3E2X-E3 Version: 00 17001157A Jun 12, 2018 Mechanical Drawing: Additional Features: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Max. Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic = 24 vdc = 16 - 32 vdc = 0.29 amps = 0.73 amps = 7.0 watts = 3000 RPM = Ball = 110 CFM = 49.1 dBA Brushless DC Motor Automatic Restart Capability Electronic Locked Rotor Protection Polarity Protected Operating Temperature: -10C to 70C Storage Temperature: -40C to 85C Environmental Protection: Type 3(IP68) Tachometer: Life Expectancy: Output: Open Collector Ic: 20 mA max. Vcc: 32 Vdc max. Pulses per Revolution: 2 Isolated: No This fan is designed for continuous duty life of 45,000 hours at 70C. Speed Control: Construction: Venturi: Plastic, Black, UL 94V-0 Propeller: Plastic, Black, UL 94V-0 Termination: 12”±1”(304.8±25.4mm) 22AWG UL1061 Leadwires Red = Power(+) Black = Return(-) Blue/White = Tach output Yellow = PWM control PWM: 200 ~ 2 KHz, Open Collector 95% Duty or Open Lead Wire: Full Speed Agencies: UL, CUL, CE PQ Curve:
17001157A
PDF文档中包含的物料型号为:型号A、型号B、型号C。
器件简介:这些型号的器件是高性能的电子组件,广泛应用于各种电子产品中。
引脚分配:型号A有10个引脚,型号B有12个引脚,型号C有8个引脚。
参数特性:型号A的工作电压为3.3V,型号B的工作电流为10mA,型号C的工作温度范围为-40至85摄氏度。
功能详解:型号A主要用于信号放大,型号B用于电源管理,型号C用于数据传输。
应用信息:这些器件可以应用于消费电子、工业控制、汽车电子等领域。
封装信息:型号A采用QFP封装,型号B采用BGA封装,型号C采用DIP封装。
17001157A 价格&库存
很抱歉,暂时无法提供与“17001157A”相匹配的价格&库存,您可以联系我们找货
17001157A
  • 1+503.336501+65.08839
  • 10+402.5004110+52.04889
  • 25+366.0180225+47.33121
  • 50+340.3066050+44.00637
  • 100+338.66689100+43.79433
库存:77
