17001160A
17001160A
    COMAIRROTRON
    风扇 管轴式 24VDC 方形 - 120mm 长 x 120mm 高 滚珠 120.0 CFM(3.36m³/min) 4 引线
17001160A 数据手册
SPECIFICATIONS Model Number: Part Number: (RoHS Compliant) MSD24K3E2X-E3 Version: 00 17001160A Jun 12, 2018 Mechanical Drawing: Additional Features: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Max. Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic = 24 vdc = 16 - 32 vdc = 0.45 amps = 1.20 amps = 10.8 watts = 3400 RPM = Ball = 120 CFM = 51.8 dBA Brushless DC Motor Automatic Restart Capability Electronic Locked Rotor Protection Polarity Protected Operating Temperature: -10C to 70C Storage Temperature: -40C to 85C Environmental Protection: Type 3(IP68) TACHOMETER: Life Expectancy: Output: Open Collector Ic: 20 mA max. Vcc: 32 Vdc max. Pulses per Revolution: 2 Isolated: No This fan is designed for continuous duty life of 45,000 hours at 70C. Speed Control: Construction: Venturi: Plastic, Black, UL 94V-0 Propeller: Plastic, Black, UL 94V-0 Termination: 12”±1”(304.8±25.4mm) 22AWG UL1061 Leadwires Red = Power(+) Black = Return(-) Blue/White = Tach output Yellow = PWM control PWM: 200 ~ 2 KHz, Open Collector 95% Duty or Open Lead Wire: Full Speed Agencies: UL, CUL, CE PQ Curve:
17001160A 价格&库存
很抱歉,暂时无法提供与“17001160A”相匹配的价格&库存,您可以联系我们找货
