17001161A
17001161A
    COMAIRROTRON
    FAN DC IP68 MSD48K3E2X-E3
17001161A 数据手册
SPECIFICATIONS Model Number: Part Number: (RoHS Compliant) MSD48K3E2X-E3 Version: 00 17001161A Jun 12, 2018 Mechanical Drawing: Additional Features: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Max. Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic = 48 vdc = 36 - 60 vdc = 0.22 amps = 1.20 amps = 10.6 watts = 3400 RPM = Ball = 120 CFM = 51.8 dBA Brushless DC Motor Automatic Restart Capability Electronic Locked Rotor Protection Polarity Protected Operating Temperature: -10C to 70C Storage Temperature: -40C to 85C Environmental Protection: Type 3(IP68) TACHOMETER: Life Expectancy: Output: Open Collector Ic: 20 mA max. Vcc: 60 Vdc max. Pulses per Revolution: 2 Isolated: No This fan is designed for continuous duty life of 45,000 hours at 70C. Speed Control: Construction: Venturi: Plastic, Black, UL 94V-0 Propeller: Plastic, Black, UL 94V-0 Termination: 12”±1”(304.8±25.4mm) 22AWG UL1061 Leadwires Red = Power(+) Black = Return(-) Blue/White = Tach output Yellow = PWM control PWM: 200 ~ 2 KHz, Open Collector 95% Duty or Open Lead Wire: Full Speed Agencies: UL, CUL, CE PQ Curve:
17001161A
物料型号:MSD48K3E2X-E3 器件简介:COMAIR ROTRON 风扇,符合RoHS标准。 引脚分配:22AWG UL1061 引线,红色代表电源(+),黑色代表返回(-),蓝/白代表转速输出,黄色代表PWM控制。 参数特性: - 额定电压:36 - 60 VDC - 额定运行电流:0.22安培 - 最大锁定转子电流:1.20安培 - 运行功率:10.6瓦特 - 转速:3400 RPM - 风量:120 CFM - 噪音:51.8 dBA - 轴承类型:球轴承 功能详解: - 无刷直流电机 - 自动重启能力 - 电子锁定转子保护 - 极性保护 - 运行温度范围:-10°C 至 70°C - 存储温度范围:-40°C 至 85°C - 环境防护等级:Type 3(IP68) - 转速控制:PWM控制,200 ~ 2 KHz,开路集电极 - 转速计:开路集电极输出,每转2脉冲 应用信息:该风扇设计用于连续工作寿命为45,000小时,工作温度为70°C。 封装信息:Venturi部分为黑色塑料,UL 94V-0认证;螺旋桨为黑色塑料,UL 94V-0认证。
17001161A 价格&库存
很抱歉,暂时无法提供与“17001161A”相匹配的价格&库存,您可以联系我们找货
17001161A
  • 300+372.25067300+48.16056
