17001163A
17001163A
    COMAIRROTRON
    风扇 管轴式 24VDC 方形 - 119.13mm 长 x 119.13mm 高 滚珠 106.0 CFM(2.97m³/min) 4 引线
17001163A 数据手册
SPECIFICATIONS Model Number: Part Number: MDD24B1E2X-E3 17001163A Version:00 Jun. 12, 2018 Mechanical Drawing: Additional Features: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic = 24 vdc = 16 - 32vdc = 0.25 amps = 1.0 amps = 6.0 watts = 3100 rpm = Ball = 106 CFM = 50 dBA Brushless DC Motor Automatic Restart Capability Electronic Locked Rotor Protection Polarity Protected Operating Temperature: -10C to 70C Storage Temperature: -40C to 85C Environmental Protection: Type 3(IP68) Tachometer: Life Expectancy: Output: Open Collector Ic: 20 mA max. Vcc: 32 Vdc max. Pulses per Revolution: 2 Isolated: No This fan is designed for continuous duty life of 55,000 hours at 70C. Speed Control: Construction: Venturi: Die-Cast Aluminum, Black Propeller: Plastic, Black, UL 94V-0 Termination: 12”±1”(304.8±25.4mm) 22AWG UL1061 Leadwires Red = Power(+) Black = Return(-) Blue/White = Tach output Yellow = PWM control PWM: 200 ~ 2 KHz, Open Collector 95% Duty or Open Lead Wire: Full Speed Agencies: UL, CUL, CE PQ Curve:
17001163A 价格&库存
很抱歉,暂时无法提供与“17001163A”相匹配的价格&库存,您可以联系我们找货
