17001167A
17001167A
    COMAIRROTRON
    FAN DC IP68 MDD48K1E2X-E3
17001167A 数据手册
SPECIFICATIONS Model Number: Part Number: MDD48K1E2X-E3 17001167A Version:00 Jun. 12, 2018 Mechanical Drawing: Additional Features: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic = 48 vdc = 36 - 60vdc = 0.16 amps = 0.60 amps = 7.7 watts = 3650 rpm = Ball = 125 CFM = 53.5 dBA Brushless DC Motor Automatic Restart Capability Electronic Locked Rotor Protection Polarity Protected Operating Temperature: -10C to 70C Storage Temperature: -40C to 85C Environmental Protection: Type 3(IP68) Tachometer: Life Expectancy: Output: Open Collector Ic: 20 mA max. Vcc: 60Vdc max. Pulses per Revolution: 2 Isolated: No This fan is designed for continuous duty life of 55,000 hours at 70C. Speed Control: Construction: Venturi: Die-Cast Aluminum, Black Propeller: Plastic, Black, UL 94V-0 Termination: 12”±1”(304.8±25.4mm) 22AWG UL1061 Leadwires Red = Power(+) Black = Return(-) Blue/White = Tach output Yellow = PWM control PWM: 200 ~ 2 KHz, Open Collector 95% Duty or Open Lead Wire: Full Speed Agencies: UL, CUL, CE PQ Curve:
17001167A 价格&库存
很抱歉,暂时无法提供与“17001167A”相匹配的价格&库存,您可以联系我们找货
17001167A
  • 300+404.10798300+52.28216
