17001166A
17001166A
    COMAIRROTRON
    FAN DC IP68 MDD24K1E2X-E3
17001166A 数据手册
SPECIFICATIONS Model Number: Part Number: MDD24K1E2X-E3 17001166A Version:00 Jun. 12, 2018 Mechanical Drawing: Additional Features: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic = 24 vdc = 16 - 32vdc = 0.34 amps = 0.75 amps = 8.2 watts = 3650 rpm = Ball = 125 CFM = 53.5 dBA Brushless DC Motor Automatic Restart Capability Electronic Locked Rotor Protection Polarity Protected Operating Temperature: -10C to 70C Storage Temperature: -40C to 85C Environmental Protection: Type 3(IP68) Tachometer: Life Expectancy: Output: Open Collector Ic: 20 mA max. Vcc: 32 Vdc max. Pulses per Revolution: 2 Isolated: No This fan is designed for continuous duty life of 55,000 hours at 70C. Speed Control: Construction: Venturi: Die-Cast Aluminum, Black Propeller: Plastic, Black, UL 94V-0 Termination: 12”±1”(304.8±25.4mm) 22AWG UL1061 Leadwires Red = Power(+) Black = Return(-) Blue/White = Tach output Yellow = PWM control PWM: 200 ~ 2 KHz, Open Collector 95% Duty or Open Lead Wire: Full Speed Agencies: UL, CUL, CE PQ Curve:
17001166A 价格&库存
很抱歉,暂时无法提供与“17001166A”相匹配的价格&库存,您可以联系我们找货
