17001169A
17001169A
    COMAIRROTRON
    FAN DC IP68 MDD48U1E2X-E3
17001169A 数据手册
SPECIFICATIONS Model Number: Part Number: MDD48U1E2X-E3 17001169A Version:00 Jun. 12, 2018 Mechanical Drawing: Additional Features: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic = 48 vdc = 36 - 60vdc = 0.8 amps = 2.00 amps = 38.4watts = 6300 rpm = Ball = 210 CFM = 65.3 dBA Brushless DC Motor Automatic Restart Capability Electronic Locked Rotor Protection Polarity Protected Operating Temperature: -10°C to 70°C Storage Temperature: -40°C to 85°C Environmental Protection: Type 3(IP68) Tachometer: Life Expectancy: Output: Open Collector Ic: 20 mA max. Vcc: 60Vdc max. Pulses per Revolution: 2 Isolated: No This fan is designed for continuous duty life of 55,000 hours at 70°C. Speed Control: Construction: Venturi: Die-Cast Aluminum, Black Propeller: Plastic, Black, UL 94V-0 Termination: 12”±1”(304.8±25.4mm) 22AWG UL1061 Leadwires Red = Power(+) Black = Return(-) Blue/White = Tach output Yellow = PWM control PWM: 200 ~ 2 KHz, Open Collector 95% Duty or Open Lead Wire: Full Speed Agencies: UL, CUL, CE PQ Curve:
17001169A 价格&库存
很抱歉,暂时无法提供与“17001169A”相匹配的价格&库存,您可以联系我们找货
17001169A
    库存:100
