SPECIFICATIONS
RoHS Compliant
Model Number:
Part Number:
GLD24B3E2X-E3
17001171A
Rev:00
Jun. 12 2018
Mechanical Drawing:
Motor:
Nominal Voltage
Operating Voltage Range
Nominal Running Current
Max. Locked Rotor Current
Running Power
Average Speed
Bearings
Air Flow
Acoustic
Construction:
Venturi:
Propeller:
= 24V DC
= 16 – 32V DC
= 0.63 Amps
= 1.35 Amps
= 15.1 Watts
= 3300 RPM
= Ball
= 150 CFM
= 53.6 dB(A)
Die Cast Aluminum, Black.
Plastic, Black, UL 94V-0.
Life Expectancy:
This fan is designed for continuous duty life of 60,000
hours at 70C (L10).
Termination:
12”±1”(304.8±25.4mm) 22AWG UL1061 Leadwires
Red
= Power(+)
Black
= Return(-)
Blue/White = Tach output
Yellow
= PWM control
Additional Features:
Brushless DC Motor
Solid State Circuitry
Electronic Locked Rotor Protected
Polarity Protection
Automatic Restart
Operating Temperature: -10 °C to +70 °C
Storage Temperature:
-40 °C to +85 °C
Environmental Protection:
Type 3(IP68)
TACHOMETER:
Output:
Ic:
Vcc:
Pulses per Revolution:
Isolated:
Open Collector
20 mA max.
32 Vdc max.
2
No
Speed Control:
PWM: 200 ~ 2 KHz, Open Collector
95% Duty or Open Lead Wire: Full Speed
Agency Approvals:
UL, CUL,CE
PQ Curve:
很抱歉,暂时无法提供与“17001171A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+664.490491+86.13062
- 10+565.5875510+73.31092
