17001174A
17001174A
    COMAIRROTRON
    FAN DC IP68 GLD24K3E2X-E3
17001174A 数据手册
SPECIFICATIONS RoHS Compliant Model Number: Part Number: GLD24K3E2X-E3 17001174A Rev:00 Jun. 12 2018 Mechanical Drawing: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Max. Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic Construction: Venturi: Propeller: = 24V DC = 16 – 32V DC = 0.95 Amps = 2.00 Amps = 22.8 Watts = 3900 RPM = Ball = 175 CFM = 57.9 dB(A) Die Cast Aluminum, Black. Plastic, Black, UL 94V-0. Life Expectancy: This fan is designed for continuous duty life of 60,000 hours at 70C (L10). Termination: 12”±1”(304.8±25.4mm) 22AWG UL1061 Leadwires Red = Power(+) Black = Return(-) Blue/White = Tach output Yellow = PWM control Additional Features: Brushless DC Motor Solid State Circuitry Electronic Locked Rotor Protected Polarity Protection Automatic Restart Operating Temperature: -10 °C to +70 °C Storage Temperature: -40 °C to +85 °C Environmental Protection: Type 3(IP68) TACHOMETER: Output: Ic: Vcc: Pulses per Revolution: Isolated: Open Collector 20 mA max. 32 Vdc max. 2 No Speed Control: PWM: 200 ~ 2 KHz, Open Collector 95% Duty or Open Lead Wire: Full Speed Agency Approvals: UL, CUL,CE PQ Curve:
17001174A 价格&库存
很抱歉,暂时无法提供与“17001174A”相匹配的价格&库存,您可以联系我们找货
