17001180A
17001180A
    COMAIRROTRON
    风扇 管轴式 48VDC 方形 - 127mm 长 x 127mm 高 滚珠 240.0 CFM(6.72m³/min) 4 引线
17001180A 数据手册
SPECIFICATIONS RoHS Compliant Model Number: Part Number: GLD48U3E2X-E3 17001180A Rev:00 Jun. 12 2018 Mechanical Drawing: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Max. Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic Construction: Venturi: Propeller: = 48V DC = 36 – 60V DC = 0.80 Amps = 1.50 Amps = 38.4 Watts = 5200 RPM = Ball = 240 CFM = 65 dB(A) Die Cast Aluminum, Black. Plastic, Black, UL 94V-0. Life Expectancy: This fan is designed for continuous duty life of 60,000 hours at 70C (L10). Termination: 12”±1”(304.8±25.4mm) 22AWG UL1061 Leadwires Red = Power(+) Black = Return(-) Blue/White = Tach output Yellow = PWM control Additional Features: Brushless DC Motor Solid State Circuitry Electronic Locked Rotor Protected Polarity Protection Automatic Restart Operating Temperature: -10 °C to +70 °C Storage Temperature: -40 °C to +85 °C Environmental Protection: Type 3(IP68) TACHOMETER: Output: Ic: Vcc: Pulses per Revolution: Isolated: Open Collector 20 mA max. 60 Vdc max. 2 No Speed Control: PWM: 200 ~ 2 KHz, Open Collector 95% Duty or Open Lead Wire: Full Speed Agency Approvals: UL, CUL,CE PQ Curve:
17001180A
1. 物料型号:GLD48U3E2X-E3 Rev 17001180A 2. 器件简介:COMAIR ROTRON,一种空气流动装置,具有黑色塑料叶片和黑色压铸铝外壳。 3. 引脚分配: - 红色线:电源正极(+) - 黑色线:返回负极(-) - 蓝/白线:转速输出 - 黄色线:PWM控制 4. 参数特性: - 额定电压:48V DC - 工作电压范围:36 – 60V DC - 额定运行电流:0.80安培 - 最大锁定转子电流:1.50安培 - 运行功率:38.4瓦特 - 平均速度:5200转/分钟 - 轴承:球轴承 - 空气流量:240立方英尺/分钟 - 噪音:65分贝(A) 5. 功能详解: - 无刷直流电机 - 固态电路 - 电子锁定转子保护 - 极性保护 - 自动重启 - 工作温度:-10°C 至 +70°C - 存储温度:-40°C 至 +85°C - 环境防护等级:Type 3(IP68) - 转速计:开路集电极输出,最大电流20毫安,最大供电电压60伏直流,每转脉冲数2,非隔离 6. 应用信息:设计用于连续工作寿命60,000小时,70°C(L10)。 7. 封装信息:22AWG UL1061导线,长度12英寸±1英寸(304.8±25.4毫米)。
17001180A 价格&库存
很抱歉,暂时无法提供与“17001180A”相匹配的价格&库存,您可以联系我们找货
17001180A
  • 1+728.883761+94.59581
  • 10+581.2232810+75.43218
  • 25+528.2860625+68.56189
  • 50+501.1481950+65.03989
