SPECIFICATIONS
RoHS Compliant
Model Number:
Part Number:
JQD48B3E2X-E3
17001183A
Rev:00
Jun 12, 2018
Mechanical Drawing:
Motor:
Nominal Voltage
Operating Voltage Range
Nominal Running Current
Locked Rotor Current
Running Power
Average Speed
Bearings
Air Flow
Acoustic
Additional Features:
= 48 vdc
= 36 - 60 vdc
= 0.46mps
= 1.0 amps
= 22.1 watts
= 3400 RPM
= Ball
= 235 CFM
= 54.3 dBA
Construction:
Venturi: Die-cast aluminum, painted black
Propeller: Plastic, painted black
Life Expectancy:
This fan is designed for continuous duty life of 58,000
hours at 70C.
Termination:
12”±1”(304.8±25.4mm) 22AWG UL1061 Leadwires
Red
= Power(+)
Black
= Return(-)
Blue/White = Tach output
Yellow
= PWM control
Brushless DC Motor
Soft Start Inrush Current
Electronic Locked Rotor Protection
Polarity Protected
Automatic Restart Capability
Operating Temperature:
-10C to 70C
Storage Temperature:
-40C to 85C
Environmental Protection:
Type 3(IP68)
TACHOMETER:
Output:
Ic:
Vcc:
Pulses per Revolution:
Isolated:
Open Collector
20 mA max.
60 Vdc max.
2
No
Speed Control:
PWM: 200 ~ 2 KHz, Open Collector
95% Duty or Open Lead Wire: Full Speed
Agency Approvals:
UL, CUL, CE
PQ Curve:
很抱歉,暂时无法提供与“17001183A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 300+636.25595300+82.12808
