17001188A
17001188A
    COMAIRROTRON
    风扇 管轴式 24VDC 方形/圆形 - 171.4mm 长 x 171.4mm 高 滚珠 332.0 CFM(9.30m³/min) 4 引线
17001188A 数据手册
SPECIFICATIONS RoHS Compliant Model Number: Part Number: JQD24U3E2X-E3 17001188A Rev:00 Jun 12, 2018 Mechanical Drawing: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic Additional Features: = 24 vdc = 16 - 32 vdc = 1.7 mps = 2.9 amps = 40.8 watts = 4830 RPM = Ball = 332 CFM = 64.0 dBA Construction: Venturi: Die-cast aluminum, painted black Propeller: Plastic, painted black Life Expectancy: This fan is designed for continuous duty life of 58,000 hours at 70C. Termination: 12”±1”(304.8±25.4mm) 22AWG UL1061 Leadwires Red = Power(+) Black = Return(-) Blue/White = Tach output Yellow = PWM control Brushless DC Motor Soft Start Inrush Current Electronic Locked Rotor Protection Polarity Protected Automatic Restart Capability Operating Temperature: -10C to 70C Storage Temperature: -40C to 85C Environmental Protection: Type 3(IP68) TACHOMETER: Output: Ic: Vcc: Pulses per Revolution: Isolated: Open Collector 20 mA max. 32 Vdc max. 2 No Speed Control: PWM: 200 ~ 2 KHz, Open Collector 95% Duty or Open Lead Wire: Full Speed Agency Approvals: UL, CUL, CE PQ Curve:
17001188A 价格&库存
很抱歉,暂时无法提供与“17001188A”相匹配的价格&库存,您可以联系我们找货
