SPECIFICATIONS
Model Number:
Part Number:
PQ24B3E2X-E3
17001191A
(RoHS Compliant)
Rev:00
Jun 12, 2018
Mechanical Drawing:
Motor:
Nominal Voltage
Operating Voltage Range
Nominal Running Current
Locked Rotor Current
Running Power
Average Speed
Bearings
Air Flow
Acoustic
Additional Features:
= 24 vdc
= 16 – 32 vdc
= 1.0 amps
= 2.00 amps
= 24 watts
= 3400 RPM
= Ball
= 235 CFM
= 54.3 dBA
Construction:
Venturi: Single piece, die-cast aluminum, Black
Propeller: Plastic, Black, UL 94V-0
Life Expectancy:
This fan is designed for continuous duty life of 58,000
hours at 70C.
Termination:
12”±1”(304.8±25.4mm) 22AWG UL1061 Leadwires
Red
= Power(+)
Black
= Return(-)
Blue/White = Tach output
Yellow
= PWM control
Brushless DC Motor
Polarity Protected
Locked Rotor Protection
Automatic Restart Capability
Operating Temperature:
Storage Temperature:
Environmental Protection:
-10C to 70C
-40C to 85C
Type 3(IP68)
TACHOMETER:
Output:
Ic:
Vcc:
Pulses per Revolution:
Isolated:
Open Collector
20 mA max.
32 Vdc max.
2
No
Speed Control:
PWM: 200 ~ 2 KHz, Open Collector
95% Duty or Open Lead Wire: Full Speed
Agency Approvals:
UL, CUL,CE
PQ Curve:
很抱歉,暂时无法提供与“17001191A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+821.294881+106.45546
- 10+654.4031010+84.82310
- 25+594.7266025+77.08789
- 50+568.7322350+73.71853
