17001192A
17001192A
    COMAIRROTRON
    FAN DC IP68 PQD48B3E2X-E3
17001192A 数据手册
SPECIFICATIONS Model Number: Part Number: PQ48B3E2X-E3 17001192A (RoHS Compliant) Rev:00 Jun 12, 2018 Mechanical Drawing: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic Additional Features: = 48 vdc = 36-60 vdc = 0.46 amps = 1.00 amps = 22.1 watts = 3400 RPM = Ball = 235 CFM = 54.3 dBA Brushless DC Motor Polarity Protected Locked Rotor Protection Automatic Restart Capability Operating Temperature: Storage Temperature: Environmental Protection: TACHOMETER: Life Expectancy: Output: Ic: Vcc: Pulses per Revolution: Isolated: This fan is designed for continuous duty life of 58,000 hours at 70C. Speed Control: Construction: Venturi: Single piece, die-cast aluminum, Black Propeller: Plastic, Black, UL 94V-0 Termination: 12”±1”(304.8±25.4mm) 22AWG UL1061 Leadwires Red = Power(+) Black = Return(-) Blue/White = Tach output Yellow = PWM control -10C to 70C -40C to 85C Type 3(IP68) Open Collector 20 mA max. 60 Vdc max. 2 No PWM: 200 ~ 2 KHz, Open Collector 95% Duty or Open Lead Wire: Full Speed Agency Approvals: UL, CUL,CE PQ Curve:
17001192A 价格&库存
很抱歉,暂时无法提供与“17001192A”相匹配的价格&库存,您可以联系我们找货
