SPECIFICATIONS
(Rohs Compliant)
Model Number:
Part Number:
PQ48K3E2X-E3
17001194A
Version: 01
Jun 12, 2018
Mechanical Drawing:
Additional Features:
Motor:
Nominal Voltage
Operating Voltage Range
Nominal Running Current
Locked Rotor Current
Running Power
Average Speed
Bearings
Air Flow
Acoustic
= 48 vdc
= 36 - 60 vdc
= 0.90 amps
= 1.50 amps
= 43.20 watts
= 4200 RPM
= Ball
= 285 CFM
= 58.9 dBA
Brushless DC Motor
Locked Rotor Protection
Polarity Protected
Automatic Restart Capability
Operating Temperature:
Storage Temperature:
Environmental Protection:
TACHOMETER:
Life Expectancy:
Output:
Ic:
Vcc:
Pulses per Revolution:
Isolated:
This fan is designed for continuous duty life of 58,000 hours
at 70C.
Speed Control:
Construction:
Venturi: Die-cast aluminum, Black
Propeller: Plastic, Black, UL 94V-0
Termination:
12”±1”(304.8±25.4mm) 22AWG UL1061 Leadwires
Red
= Power(+)
Black
= Return(-)
Blue/White = Tach output
Yellow
= PWM control
-10C to 70C
-40C to 85C
Type 3(IP68)
Open Collector
20 mA max.
60 Vdc max.
2
No
PWM: 200 ~ 2 KHz, Open Collector
95% Duty or Open Lead Wire: Full Speed
Agency Certifications:
UL, CUL, CE
PQ Curve:
170
m3/Hr
255
340
425
510
595
1.0
250
0.8
200
0.6
150
0.4
100
0.2
50
0.0
100
150
200
CFM
250
300
350
Pa
300
Static Pressure (in H2O)
1.2
很抱歉,暂时无法提供与“17001194A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+690.624881+89.51814
- 10+625.6672110+81.09839
