17001195A
17001195A
    COMAIRROTRON
    FAN DC IP68 PQD24Z3E2X-E3
17001195A 数据手册
SPECIFICATIONS Model Number: Part Number: PQD24Z3E2X-E3 17001195A Rev: 00 Jun 12, 2018 Mechanical Drawing: Additional Features: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Air Flow Max. Static Pressure Acoustic = 24 vdc = 16 – 32 vdc = 1.30 amps = 3.00 amps = 31.2 watts = 4500 rpm = Ball = 305 CFM = 1.37” H2O = 60.4 dBA Construction: Venturi: Die-Cast Aluminum, Black Propeller: Polycarbonate, Black, UL 94V-0 Termination: 12”±1”(304.8±25.4mm) 22AWG UL1061 Leadwires Red = Power(+) Black = Return(-) Blue/White = Tach output Yellow = PWM control Brushless DC Motor Soft Start Inrush Current Electronic Locked Rotor Protection Polarity Protected Automatic Restart Capability Operating Temperature: -10C to 70C Storage Temperature: -40C to 85C Environmental Protection: Type 3(IP68) TACHOMETER: Output: Ic: Vcc: Pulses per Revolution: Isolated: Open Collector 20 mA max. 32 Vdc max. 2 No Speed Control: PWM: 200 ~ 2 KHz, Open Collector 95% Duty or Open Lead Wire: Full Speed Agency Approvals: UL, CUL, CE PQ Curve:
17001195A 价格&库存
很抱歉,暂时无法提供与“17001195A”相匹配的价格&库存,您可以联系我们找货
