17001196A
17001196A
    COMAIRROTRON
    风扇 管轴式 48VDC 圆形 - 171.4mm 直径 滚珠 305.0 CFM(8.54m³/min) 4 引线
17001196A 数据手册
SPECIFICATIONS (RoHS Compliant) Model Number: Part Number: PQD48Z3E2X-E3 17001196A Version: 00 Jun 12, 2018 Mechanical Drawing: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic Additional Features: = 48 vdc = 36 – 60 vdc = 0.67 amps = 1.5 amps = 32.2 watts = 4500 rpm = Ball = 305 CFM = 60.4 dBA TACHOMETER: Construction: Venturi: Die-Cast Aluminum, Black Propeller: Polycarbonate, Black, UL 94V-0 Life Expectancy: This fan is designed for continuous duty life of 58,000 hours at 70C. Termination: 12”±1”(304.8±25.4mm) 22AWG UL1061 Leadwires Red Black Blue/White Yellow Brushless DC Motor Soft Start Inrush Current Electronic Locked Rotor Protection Polarity Protected Automatic Restart Capability Operating Temperature: -10C to 70C Storage Temperature: -40C to 85C Environmental Protection: Type 3(IP68) = Power(+) = Return(-) = Tach output = PWM control Output: Ic: Vcc: Pulses per Revolution: Isolated: Open Collector 20 mA max. 60 Vdc max. 2 No Speed Control: PWM: 200 ~ 2 KHz, Open Collector 95% Duty or Open Lead Wire: Full Speed Agency Approvals: UL, CUL, CE PQ Curve:
17001196A 价格&库存
很抱歉,暂时无法提供与“17001196A”相匹配的价格&库存,您可以联系我们找货
17001196A
  • 1+690.624881+89.51814
  • 10+625.6672110+81.09839
库存:13
