SPECIFICATIONS
Model Number:
Part Number:
PQD24U3E2X-E3
17001197A
Version: 00
Jun 12, 2018
Mechanical Drawing:
Motor:
Nominal Voltage
Operating Voltage Range
Nominal Running Current
Locked Rotor Current
Running Power
Average Speed
Bearings
Air Flow
Acoustic
Additional Features:
= 24 VDC
= 16 - 32 VDC
= 1.70amps
= 3.5A
= 40.8 watts
= 4830 RPM
= Ball
= 332 CFM
= 64 dBA
Construction:
Brushless DC Motor
Soft Start Inrush Current
Electronic Locked Rotor Protection
Polarity Protected
Automatic Restart Capability
Operating Temperature:
-10C to 70C
Storage Temperature:
-40C to 85
Environmental Protection:
Type 3(IP68)
Tachometer Specifications:
Life Expectancy:
Open Collector
Ic:
20 mA. Max
Vcc:
32 VDC Max.
Pulses per Revolution: 2
Isolated:
No
This fan is designed for continuous duty life of 58,000
hours at 70C.
Speed Control:
Venturi: Die-Cast Aluminum, Black
Propeller: Polycarbonate, Black, UL 94V-0
Termination:
12”±1”(304.8±25.4mm) 22AWG UL1061 Leadwires
Red
= Power(+)
Black
= Return(-)
Blue/White = Tach output
Yellow
= PWM control
Output:
PWM: 200 ~ 2 KHz, Open Collector
95% Duty or Open Lead Wire: Full Speed
Agency Approvals:
UL,CUL ,CE
PQ Curve:
很抱歉,暂时无法提供与“17001197A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+882.397551+114.23400
