SPECIFICATIONS
Model Number:
Part Number:
PQD48U3EX2-E3
17001198A
Version: 00
Jun 12, 2018
Mechanical Drawing:
Motor:
Nominal Voltage
Operating Voltage Range
Nominal Running Current
Locked Rotor Current
Running Power
Average Speed
Bearings
Air Flow
Acoustic
Additional Features:
= 48 VDC
= 36 - 60 VDC
= 0.85 amps
= 1.5A
= 40.8watts
= 4830 RPM
= Ball
= 332 CFM
= 64 dBA
Brushless DC Motor
Soft Start Inrush Current
Electronic Locked Rotor Protection
Polarity Protected
Automatic Restart Capability
Operating Temperature:
-10C to 70C
Storage Temperature:
-40C to 85
Environmental Protection:
Type 3(IP68)
Construction:
TACHOMETER:
Venturi: Die-Cast Aluminum, Black
Propeller: Polycarbonate, Black, UL 94V-0
Output:
Ic:
Vcc:
Pulses per Revolution:
Isolated:
Life Expectancy:
This fan is designed for continuous duty life of 58,000 hours
at 70°C.
Termination:
12”±1”(304.8±25.4mm) 22AWG UL1061 Leadwires
Red
= Power(+)
Black
= Return(-)
Blue/White = Tach output
Yellow
= PWM control
Open Collector
20 mA max.
60 Vdc max.
2
No
Speed Control:
PWM: 200 ~ 2 KHz, Open Collector
95% Duty or Open Lead Wire: Full Speed
Agency Approvals:
UL, CUL ,CE
PQ Curve:
很抱歉,暂时无法提供与“17001198A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+825.110971+106.95009
