AB21RS
AB21RS
    COMUS(康姆斯)
    SOP-4
    固态 SPST-NO(1 Form A) 4-SOP(0.173",4.40mm)
AB21RS 数据手册
Relays Part Number: 21RS Series General Purpose - 1 Form A / 2 Form A - PhotoDMOS Relays Product Data Sheet PICTURE Low Capacitance / Resistance SCHEMATIC AB21RS 4 4.3 4.4 2.0 9.4 SOP8 1 (+) ORDERING INFORMATION AB = 4 pin AC = 8 pin 21RS 1 2 (-) (+) 1: Anode (LED) 2: Cathode (LED) 3, 4: Drain (MOS FET) Drawings not to scale. All dimensions in mm nominal. Pitch: 2.54 mm Series 8 3 7 6 5 4.4 2.0 SOP4 Body Style AC21RS 2 (-) 3 (+) 1, 3: Anode 2, 4: Cathode 5, 6, 7, 8: Drain 4 (-) (LED) (LED) (MOS FET) FEATURES • PhotoDMOS Relays • 40 Volt, 250 mA • On-Resistance: 0.9 Ω (typical) • I/O Breakdown Voltage: 1500 Vrms Min. • Output Capacitance: 13 pF • Max LED Current 3.0 mA • Low Off-State Leakage Current 10 μ A Max • UL File E344988 Options R1 = Tape & Reel Part Number Example: XX21RS-XX AC21RS-R1 = Series 21RS, 2 Form A, 8 Pin, with tape and reel packaging ® ABSOLUTE MAXIMUM RATINGS (Ambient Temperature: 25°C) ITEM SYMBOL VALUE IF 50 mA Peak LED Current (f=100 Hz, duty=1%) IFP 500 mA LED Reverse Voltage VR 5V Input Power Dissipation PIn 75 mW Load Voltage VL 40 V (AC peak or DC) Load Current (mA) IL 250 Peak Load Current (1 ms, 1 shot) (mA) IPeak 750 Output Power Dissipation (mW) POut 350 (1ch) 400 (2ch) PT 350 (1ch) 450 (2ch) Continuos LED Current Input Output Total Power Dissipation (mW) I/O Breakdown Voltage (Vrms) VI/O 1500 Operating Temperature TOpr -40˚ +85˚C Storage Temperature TStg -40˚ +100˚C As part of the company policy of continued product improvement, specifications may change without notice. Our sales office will be pleased to help you with the latest information on this product range and the details of our full design and manufacturing service. All products are supplied to our standard conditions of sale unless otherwise agreed in writing. Phone: (1) 973 777 6900 www.comus-intl.com Fax: (1) 973 777 8405 Belgium: + 32 (0)12 390400 - Comus Europe Ltd (Assemtech) UK: +44 (0) 1255 862236 - Germany: +49 (0)911 923 15 943 - Netherlands: +31(0)45 54 39 345 - India: +(91) (44) 42023510 ©2019 Copyright Comus International, 454 Allwood Road, Clifton NJ 07012, USA Rev: 0 - Date: Jan/3/2019 - Signature: BR An ISO 9001 Certified Company Relays Part Number: 21RS Series General Purpose - 1 Form A / 2 Form A - PhotoDMOS Relays Product Data Sheet Low Capacitance / Resistance ELECTRICAL SPECIFICATIONS (Ambient Temperature: 25˚C) ITEM Input Output Transmission Coupled SYMBOL MIN TYP MAX LED Forward Voltage VF 1.0 1.17 1.5 V Operation LED Current IF On 0.3 3.0 mA Recovery LED Voltage VF Off On-Resistance Drain to Drain ROn 0.9 1.25 Ω IF = 5mA IL = Rating Time to flow is within 1 sec. Off-State Leakage Current ILeak 0.03 10 μA VL= 40V Output Capacitance COut 13 pF VL= 0V, f= 1MHz Turn-On Time TOn 0.07 0.5 ms Turn-Off Time TOff 0.05 0.2 ms IF = 5mA IL = Rating I/O Insulation Resistance RI/O I/O Capacitance CI/O 0.5 1.0 109 UNITS CONDITIONS IF = 10mA V Ω 0.8 pF f = 1MHz As part of the company policy of continued product improvement, specifications may change without notice. Our sales office will be pleased to help you with the latest information on this product range and the details of our full design and manufacturing service. All products are supplied to our standard conditions of sale unless otherwise agreed in writing. Phone: (1) 973 777 6900 www.comus-intl.com Fax: (1) 973 777 8405 Belgium: + 32 (0)12 390400 - Comus Europe Ltd (Assemtech) UK: +44 (0) 1255 862236 - Germany: +49 (0)911 923 15 943 - Netherlands: +31(0)45 54 39 345 - India: +(91) (44) 42023510 ©2019 Copyright Comus International, 454 Allwood Road, Clifton NJ 07012, USA Rev: 0 - Date: Jan/3/2019 - Signature: BR An ISO 9001 Certified Company Relays Part Number: 21RS Series General Purpose - 1 Form A / 2 Form A - PhotoDMOS Relays Product Data Sheet Low Capacitance / Resistance GRAPHS As part of the company policy of continued product improvement, specifications may change without notice. Our sales office will be pleased to help you with the latest information on this product range and the details of our full design and manufacturing service. All products are supplied to our standard conditions of sale unless otherwise agreed in writing. Phone: (1) 973 777 6900 www.comus-intl.com Fax: (1) 973 777 8405 Belgium: + 32 (0)12 390400 - Comus Europe Ltd (Assemtech) UK: +44 (0) 1255 862236 - Germany: +49 (0)911 923 15 943 - Netherlands: +31(0)45 54 39 345 - India: +(91) (44) 42023510 ©2019 Copyright Comus International, 454 Allwood Road, Clifton NJ 07012, USA Rev: 0 - Date: Jan/3/2019 - Signature: BR An ISO 9001 Certified Company
AB21RS 价格&库存
很抱歉,暂时无法提供与“AB21RS”相匹配的价格&库存,您可以联系我们找货
