RBF-40T
RBF-40T
    COMUS(康姆斯)
    安全灯 危险,安全
RBF-40T 数据手册
Group Part Number: RBF-40T Flashing Safety Light - Tilt Activated, Fully Sealed Product Datasheet DIMENSIONS PICTURE 0.070 (1.78) 0.570 (14.48) 2.750 (69.85) Ø 0.230 (5.84) Ø 0.590 (14.99) FEATURES Rotate Flasher 90˚ to Turn New OFF ● Robust 3.500 (88.90) 1.110 (28.19) Slim Design ● Vibration Resistant ● No Mechanical Parts ● Plug and Play Device ● 3 Bright Pulses Every 1.050 (26.67) Flash 0.160 (4.06) 1.700 (43.18) 3.380 (85.85) NOTE: Flasher can be mounted on either side of the lift gate after activation. Rotate Flasher 90˚ 4X to Turn ON 4.320 (109.73) Drawings not to scale. All dimensions in mm nominal. Rotate Flasher 90˚ to Turn OFF OPERATION ACTIVATION OFF 40° INITIAL POSITION INITIAL POSITION Rotate Flasher 90˚ to Turn OFF Rotate Flasher 90˚ to Turn OFF ON 180° 0° Rotate Flasher 90˚ 4X to Turn ON Operation Angle Rotate FlasherRotate 90° 4X (from Flasher 90˚initial 4X to position) Turn ON to Turn ON Degree RotateFlasher Flasher 90˚ OFFOFF Rotate 90°totoTurn Turn Rotate Flasher 90˚ 4X to Turn ON SPECIFICATION 40° Tilt (see above for activating flasher) Battery Life Aprox 3 years (1 hour a day, under normal conditions) Number of LED’s 6 Operating Temperature Celsius -20° to 85° Flash Rate P/min 35 / min (3 bright pulse every flash, duration 1/2 second) Battery Voltage (non replaceable) Volts 3.6 Fixing Holes 3 x 5.8 mm IP Rating 68 Material Resin filled Polycarbonate Shell Rotate Flasher 90˚ 4X to Turn As part of the company policy of continued product improvement, specifications may change without notice. Our sales office will be pleased to help you with the latest information on this product range and the details of our full design and manufacturing service. All products are supplied to our standard conditions of sale unless otherwise agreed in writing. Phone: (1) 973 777 6900 www.comus-intl.com Fax: (1) 973 777 8405 Belgium: + 32 (0)12 390400 - Comus Europe Ltd (Assemtech) UK: +44 (0) 1255 862236 - Germany: +49 (0)911 923 15 943 - Netherlands: +31(0)45 54 39 345 - India: +(91) (44) 43219090 ©2019 Copyright Comus International, 454 Allwood Road, Clifton NJ 07012, USA 5 / 2019 An ISO 9001 Certified Company
RBF-40T 价格&库存
很抱歉,暂时无法提供与“RBF-40T”相匹配的价格&库存,您可以联系我们找货
