ME60A0503N01
ME60A0503N01
    SLPOWER
    AC/DC DESKTOP ADAPTER
ME60A0503N01 数据手册
ME60 60W Single Output External Power Medical Series Features  Meets UL/EN/IEC60601-1-2, 4th edition for EMC  Approved to EN/IEC/UL60601-1, 3rd edition and EN/IEC/UL60601-1-11:2010 for Home Healthcare (non-hospital use) applications with and isolation levels which satisfy the 2 MOPP requirements  Meets DoE Efficiency Level VI Requirements  No load input power  Average Efficiency  Up to 60W of AC-DC Power  Universal Input 90-264Vac Input Range  Desktop and Wall-Plug versions  Meets EN55011/CISPR11, FCC Part 15.109 Class B Conducted & Radiated Emissions, with 6db margin  E-cap life of >7 years  3 Year Warranty  RoHS Compliant Description A high performance AC to DC external power supply family designed for medical applications. The ME60A Medical Series low power external AC-DC power supplies are approved to safety EN/IEC/UL60601-1, 3rd edition and EN/IEC/UL606011-11:2010 for Home Healthcare (non-hospital use) applications with and isolation levels which satisfy the 2 MOPP requirements and designed to UL/EN/IEC60601-1-2, 4th edition for EMC. The ME60A Series models will operate at universal input range of 90 to 264Vac over the wide temperature range of -20°C to +50°C, delivering full rated output power up to +40°C and applicable output power derating at 50°C. These models are available in desktop versions, include an IP22 rating per IEC60529 for the enclosure, and the output cable can be terminated at a variety of output connectors. Model Selection Model Number ME60A0503F01 ME60A1203F01 ME60A2403F01 ME60A0503N01 ME60A1203N01 ME60A2403N01 ME60A0503Q01 ME60A1203Q01 ME60A2403Q01 Notes: Volts 12.0V 24.0V 48.0V 12.0V 24.0V 48.0V 12.0V 24.0V 48.0V Output Current 5.00A 2.70A 1.35A 5.00A 2.70A 1.35A 5.00A 2.70A 1.35A Output Power 60W 60W 60W 60W 60W 60W 60W 60W 60W Ripple & Noise¹ 120mV pk-pk 240mV pk-pk 480mV pk-pk 120mV pk-pk 240mV pk-pk 480mV pk-pk 120mV pk-pk 240mV pk-pk 480mV pk-pk Line Regulation ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% Load Regulation ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% Output Connector Input Configuration 2.5 x 5.5 x 9.5mm Straight Barrel Type, center positive Class I Desktop, IEC60320 C14 Receptacle 2.5 x 5.5 x 9.5mm Straight Barrel Type, center positive Class II Desktop, IEC60320 C8 Receptacle 2.5 x 5.5 x 9.5mm Straight Barrel Type, center positive Class II Desktop, IEC60320 C18 Receptacle 1. Measured at the output connector, with noise probe directly across output and load terminated with 0.1μF ceramic and 10μF low ESR capacitors. 2. Order blade kit KT-1027K for other blades (EU. UK, Australia) 3. For EU fixed blades, replace “C” in the model number with “M”, for UK blades, replace “C” with “G”, for Australia blades, replace “C” with “H”. www.slpower.com ME60 Rev 1.0 16-JUN-15 PRELIMINARY 1 ME60 60W Single Output External Power Medical Series General Specifications AC Input Input Current Inrush Current Input Fuses Earth Leakage Current Efficiency 100-240Vac, ±10%, 47-63Hz, 1∅ Turn On Time Less than 700mS @115Vac, full load 115Vac: A, 230Vac: A A max. at 90Vac Hold-up Time 20mS min., at full Load, 100Vac input 264Vac, cold start: will not exceed 40A F1, F2: TBDA, 250Vac fuses (line & neutral lines) provided on all models Overvoltage Protection No Load Input Power 87%, typical 10 to 12W continuous – See models chart for specific voltage model ratings. Output Voltage Overload Protection Input-GND: 7 year life based on calculations at 115Vac/60Hz & 230Vac/50Hz, ambient 25°C at 24 hrs per day, 365 days/year, 6 power up cycles per day. PRELIMINARY 2 ME60 60W Single Output External Power Medical Series EMI/EMC Compliance Conducted Emissions: EN55011/CISPR22 Class B, FCC Part 15.107, Class B: 6db margin typ, at 115 and 230Vac Radiated Emissions: EN55022/CISPR22 Class B, FCC Part 15.109, Class B: 3db margin typ, at 115 and 230Vac Common Mode Noise: High Frequency (100kHz-20MHz):
ME60A0503N01 价格&库存
很抱歉,暂时无法提供与“ME60A0503N01”相匹配的价格&库存,您可以联系我们找货
