A28SS
A28SS
    CONDUCTRF
    FLEXIBLE 0.085 COAX CABLE
A28SS 数据手册
A28SS-Rev2 Performance Cable Specification Flexible, Spiral Strip/Braided, Coaxial Cable Construction Item Material Diameter Characteristic 1. Center Conductor Silver Plated Copper Clad Steel Wire 0.51mm (0.020”) Solid 2. Dielectric PTFE 1.63mm (0.064”) Solid 3. Outer Conductor(1) Silver Plated Copper Flat Tape 1.80mm (0.071”) Tape 4. Outer Conductor(2) Silver Plated Copper Braid 2.18mm (0.086”) Braid 5. Jacket FEP 2.64mm (0.104”) Blue Electrical & Mechanical Data Characteristic impedance Operating frequency Velocity of propagation Signal delay 50 Ohm 27GHz (Max.) 70% 4.72ns/m Capacitance 95pF/m Operating temperature Shield effectiveness to 18GHz Working Voltage Weight -55ºC ~ 165ºC > 90dB 1500Vrms (Max) 19.1kg/km Min. bending radius Performance Data Frequency 6mm (Single) 20mm (Multiple) - (GHz/100ft - K1=22.500/K2=0.700) Max Attenuation Max. Power (GHz) dB/100m dB/100ft (Watt) 1 2 6 12 16 18 20 27 76.10 132.84 194.54 283.20 331.94 356.21 375.95 445.46 23.20 40.50 59.31 86.34 101.20 108.60 114.62 135.81 140.00 95.00 57.00 39.00 35.00 33.00 31.00 27.00 www.ConductRF.com Tel: +978 374 6840 sales@ConductRF.com
A28SS 价格&库存
很抱歉,暂时无法提供与“A28SS”相匹配的价格&库存,您可以联系我们找货
