FMA28-S1S1-S12
FMA28-S1S1-S12
    CONDUCTRF
    CBL ASSY SMA M-SMA M 12
FMA28-S1S1-S12 数据手册
Reformable 50Ω RF Cables 0.047”, 0.085” & 0.141” Cable Options Standard Connector Interfaces 0.047” 0.085” & 0.141” Hand Formable Cable Frequency Options up to 40GHz Low VSWR & Insertion Loss Reformable during installation FEP Jacketed Cable Options Simple Part Number Configuration Characteristic Centre Conductor Material Dia 0.047” Dia 0.085” SPCW Dia 0.141” SPCCS Dielectric Material Solid PTFE Outer Braid Copper Foil/Tin Composite Cable Jacket Unjacketed or FEP Capacitance 29.4pF/ft Velocity of Propagation 1.45ns/ft Shielding up 18GHz -95dB min. Operating Temp. Range Typ. Dia. over Jacket With the additional benefit of higher shielding effectiveness and RF performance over traditional standard flexible cables, hand forming solutions provide a great performance alternative, often at no extra cost. When compared to traditional semi-rigid options, these cables can provide increased installation flexibility at a substantially lower cost. 70% Nominal Electrical Delay -55ºC to +125ºC 0.063” 0.100” 0.162” 900Vrms 1,500Vrms 1,900Vrms Static Min. Bend Radius 0.100” 0.240” 0.320” Maximum CW Power(1GHz) 51.4W 121.5W 303.4W Atten. /100ft (20C-SL) 1GHz 42.9dB 19.7dB 12.1dB Max Op. Voltage ConductRF FM series of Hand Formable RF cable assemblies provides system designers with a versatile solution that allows RF cables to be physically routed and set in to position during installation. ConductRF’s Formed cables are manufactured using the latest induction soldering techniques to best ensure the highest quality and 100% tested to validate performance because, Results Count! FMA28-S1S1-S09 FMXXX-YZYZ-YYY XXX A28 = 0.085” Hand Form(18GHz Max) X28 = 0.085” Hand Form(40GHz Max) A29 = 0.141” Hand Form(18GHz Max) A33 = 0.047” Hand Form(40GHz Max) J28 = 0.085” Hand Form w. FEP Jacket(18GHz) J29 = 0.141” Hand Form w. FEP Jacket(18GHz) J33 = 0.047” Hand Form w/ FEP Jacket(40GHz) 20C-FM Y(Max Frequency) M = MCX(6GHz) N = Type-N(18GHz) S = SMA(18GHz) D = 2.92mm(40GHz) P= SMP(27GHz) More on Request Z 1 = Straight Male 2 = R/A Male 3 = BKHD Mount Female 4 = Panel Mount Female F = Straight Female Sales@ConductRF.com - Tel: +1 978 374 6840 - YYY SYY = Length in in.(S09 = 9”) CYY = Length in CM(C50 = 50cm) www.ConductRF.com
FMA28-S1S1-S12 价格&库存
很抱歉,暂时无法提供与“FMA28-S1S1-S12”相匹配的价格&库存,您可以联系我们找货
