Reformable 50Ω RF Cables
0.047”, 0.085” & 0.141” Cable Options
Standard Connector Interfaces
0.047” 0.085” & 0.141” Hand Formable Cable
Frequency Options up to 40GHz
Low VSWR & Insertion Loss
Reformable during installation
FEP Jacketed Cable Options
Simple Part Number Configuration
Characteristic
Centre Conductor Material
Dia 0.047”
Dia 0.085”
SPCW
Dia 0.141”
SPCCS
Dielectric Material
Solid PTFE
Outer Braid
Copper Foil/Tin Composite
Cable Jacket
Unjacketed or FEP
Capacitance
29.4pF/ft
Velocity of Propagation
1.45ns/ft
Shielding up 18GHz
-95dB min.
Operating Temp. Range
Typ. Dia. over Jacket
With the additional benefit of higher
shielding effectiveness and RF
performance over traditional standard
flexible cables, hand forming solutions
provide a great performance alternative,
often at no extra cost. When compared to
traditional semi-rigid options, these cables
can provide increased installation flexibility
at a substantially lower cost.
70% Nominal
Electrical Delay
-55ºC to +125ºC
0.063”
0.100”
0.162”
900Vrms
1,500Vrms
1,900Vrms
Static Min. Bend Radius
0.100”
0.240”
0.320”
Maximum CW Power(1GHz)
51.4W
121.5W
303.4W
Atten. /100ft (20C-SL) 1GHz
42.9dB
19.7dB
12.1dB
Max Op. Voltage
ConductRF FM series of Hand Formable RF
cable assemblies provides system designers
with a versatile solution that allows RF
cables to be physically routed and set in to
position during installation.
ConductRF’s Formed cables are
manufactured using the latest induction
soldering techniques to best ensure the
highest quality and 100% tested to
validate performance because, Results
Count!
FMA28-S1S1-S09
FMXXX-YZYZ-YYY
XXX
A28 = 0.085” Hand Form(18GHz Max)
X28 = 0.085” Hand Form(40GHz Max)
A29 = 0.141” Hand Form(18GHz Max)
A33 = 0.047” Hand Form(40GHz Max)
J28 = 0.085” Hand Form w. FEP Jacket(18GHz)
J29 = 0.141” Hand Form w. FEP Jacket(18GHz)
J33 = 0.047” Hand Form w/ FEP Jacket(40GHz)
20C-FM
Y(Max Frequency)
M = MCX(6GHz)
N = Type-N(18GHz)
S = SMA(18GHz)
D = 2.92mm(40GHz)
P= SMP(27GHz)
More on Request
Z
1 = Straight Male
2 = R/A Male
3 = BKHD Mount Female
4 = Panel Mount Female
F = Straight Female
Sales@ConductRF.com - Tel: +1 978 374 6840 -
YYY
SYY = Length in in.(S09 = 9”)
CYY = Length in CM(C50 = 50cm)
www.ConductRF.com
很抱歉,暂时无法提供与“FMA28-S1M1-S24”相匹配的价格&库存,您可以联系我们找货
