LSA61-B1B1-S18
LSA61-B1B1-S18
    CONDUCTRF
    CBL ASSY 1.85MM M-1.85MM M 18
LSA61-B1B1-S18 数据手册
Hi-Frequency Flexible RF Jumper Cables Solutions for Internal X-Connect 1.85mm, 2.4mm & 2.92mm Connectors Solutions for 40GHz, 50GHz & 67GHz Excellent Phase Stability Stainless Steel Connector Interfaces Double Shielded Effective >100dB Low VSWR & Loss Frequency & Interface Markers Ideal for X Connect of RF Modules Ideal for Military & Commercial systems Characteristic 40GHz 50GHz 67GHz Interface Std. 2.92mm(K) 2.4mm 1.85mm(V) VSWR(Typical) 1.25:1 1.30:1 VSWR(Max) 1.40:1 1.45:1 Cable Attm(db/ft) 1.60dB 1.84db 2.22dB ILmax (12” Assy) 2.15dB 2.45dB 2.93dB 30W 25W 19W Max Power Phase Change +/- 8Deg to 67GHz Minimum Bend 13mm (0.5”) Velocity of Prop. 75% Capacitance 89pF/m Shielding Effect. > 100dB Temp Range -65 to 105C Images for illustration only, Data subject to change. Performance measured at 25C. Part Number Structure ConductRF’s latest innovation is Hi-Frequency RF Jumper Cables with 2.92mm, 2.4mm or 1.85mm connectors as standard. This assemblies use our optimized direct solder attached connectors and our superior double shielded hi-frequency A61SW flexible cable with shielding effectiveness greater than -100dB. These cables are design to support the latest requirements for 5G applications for cross connecting modules, but can equally be used in any field where hi-frequency jumper cables are required. Beyond our standard interconnect, we can also offer solutions with SMP, SMPM, SMA and many other common connector interfaces. Hi-Performance right angled options are available utilizing hard setting shrink tube to form the cable bend. LSA61-C1C1-S18 LSA61-YZYZ-YYY Typical Plot LSA61-B1B1-S12 YYY = Length FYY = in Feet(F06 = 6ft) SYY = in Inches(S18 = 18”) YMY = in Meters(2M5 = 2.5m) CYY = in Centimeters(C50 = 50cm) Max Length 10ft(3M) Y B = 1.85mm C = 2.4mm D = 2.92mm E = 3.5mm S = SMA P = SMP 20A-LSA61 Z 1 = Straight Male F = Straight Female 2 = R/A Male R = R/A Female Sales@ConductRF.com - Tel: +1 978-374-6840 - www.ConductRF.com
LSA61-B1B1-S18 价格&库存
很抱歉,暂时无法提供与“LSA61-B1B1-S18”相匹配的价格&库存,您可以联系我们找货
