LSA29-N1N2-S60
LSA29-N1N2-S60
    CONDUCTRF
    CBL ASSY N M - N M RA 60"
LSA29-N1N2-S60 数据手册
Performance Flexible RF Cables 0.141” & 0.086” Cable Types Up to 18GHz Solutions 50Ω Connector options including; SMA, Type-N, TNC, SMP, MCX & more Str & R/A Male and Bkhd Female solutions Low Profile 18GHz N & SMA R/A Solutions Low VSWR Connector Options Double Shielded Low Loss Cable Corrosion Resistant Connectors Weatherproof Options Available Connector Style 6GHz 12GHz 18GHz (SMB 4GHGz) VSWRmax - SMA 1.10:1 1.20:1 1.25:1 VSWRmax - Type-N 1.10:1 1.20:1 1.30:1 VSWRmax - TNC 1.15:1 1.25:1 1.35:1 VSWRmax - SMP 1.20:1 1.28:1 1.38:1 VSWRmax - SMB-4GHz 1.30:1 VSWRmax - MCX & MMCX 1.35:1 IL(dB) - A28 - 1ft 0.895 1.293 1.609 IL(dB) - A28 - 2ft 1.547 2.242 2.797 IL(dB) - A28 - 3ft 2.200 3.192 3.986 ConductRF LSA series of Low Loss, Performance flexible RF cable assemblies, provide microwave system designers with a versatile solution for most applications. Here we offer customers a solution for 0.086”dia. cable that facilitates greater flexibility and handling or, 0.141”dia. that exploits the same great performance but with almost half the loss. Connector options include SMA, Type-N, TNC, SMB & SMP that provide excellent VSWR between DC and 18GHz, also solutions for MCX & MMCX are available in a wide array of configurations. These assemblies are built using our own double shielded, FEP jacketed cable, that was developed specifically for performance solutions. With shielding effectiveness exceeding 90dB through 18GHz, these cables minimize the threat of cross-talk effect. 6mm Single / 20mm Multiple Min Bend A28 IL(dB) - A29 - 1ft 0.605 0.890 1.122 IL(dB) - A29 - 2ft 0.968 1.437 1.824 IL(dB) - A29 - 3ft 1.331 1.984 2.525 Min Bend A29 10mm Single / 40mm Multiple ConductRF guarantees it’s performance through 100% factory test prior to shipping. Additional options are also available with enhanced bonded strain relief and rear seals to support cables that are weatherproof in the mated condition. Data subject to change. LSA29-S1S1-F05 LS#XX-YZYZ-YYY # A = Standard/Internal Use E = Weather Enhanced YYY FYY = Length in Ft(F06 = 6ft) SYY = Length in In.(S18 = 18”) YMY = Length in M(2M5 = 2.5m) CYY = Length in CM(C50 = 50cm) XX 28 = 0.086” Dia Cable 29 = 0.141” Dia Cable Y SMA = S Type-N = N TNC = T MCX = M SMB = B SMP = P MMCX = See Note 20B-LSA Z 1 = Straight Male 2 = Right Angle Male 3 = Bulkhead Female Note - MMCX Styles are Reversed i.e. ZYZY or 1M & 2M for Straight & R/A Males. Example - LSA28-S11M-S06 = SMA male to MMCX male Sales@ConductRF.com - Tel: +1 978 374 6840 - www.ConductRF.com
LSA29-N1N2-S60 价格&库存
很抱歉,暂时无法提供与“LSA29-N1N2-S60”相匹配的价格&库存,您可以联系我们找货
