FPA28C-PMRPMR-S24
FPA28C-PMRPMR-S24
    CONDUCTRF
    CBL ASSY SMPM JACK 24
FPA28C-PMRPMR-S24 数据手册
Semi-“FlexiForm” 50Ω RF Cables ø0.047”, ø0.085” & ø0.141” Cable Options Standard Connector Interfaces Solutions up to 90GHz Low VSWR & Insertion Loss Operating Temps up to 125ºC FEP Jacketed Cable Formable Bending during installation Ideal for Phase Matching & Precision Lengths ConductRF Cable # A33RFJ A28RFJ A29RFJ Outer Shield Diemeter ø0.047” ø0.085” ø0.141” Centre Conductor Material Silver Plated OFHC Solid Copper Laminated PTFE Dielectric Material Outer Braid 1 Silver Plated OFHC Copper Foil Outer Braid 2 Tin Plated OFHC Copper Braid Cable Jacket Black FEP Capacitance 95pF/m Available in 3 common cable diameters, with the benefits of higher operating frequencies, shielding effectiveness and stability performance over traditional standard Hand Formable cables, these solutions enhance any application requiring higher performance. 71% Velocity of Propagation 4.59ns/m Electrical Delay >100dB Shielding to 18GHz -55ºC to +125ºC Operating Temp. Range Jacket Diameter ø0.067” ø0.104” ø0.168” Max Op. Voltage 900Vrms 1,500Vrms 1,900Vrms 3mm 5mm 10mm 90GHz 60GHz 33GHz Static Min. Bend Radius Cable Max Frequency ConductRF FPA Cable Assemblies use a unique, Low Loss, high performance Semi-“FlexiForm” Cable that is formable, but flexible, providing system designers with a versatile solution for High Frequency applications. The product also allows for very tight phase matching to ±0.2º. ConductRF’s FPA Cable Assemblies are manufactured using the latest induction soldering techniques to best ensure the highest quality and performance because, Results Count! FPA28-D1D1-S06 FPAXX-YZYZ-YYY XXX(Max Frequency) A28 = 0.085”(Up to 60GHz) A29 = 0.141”(Up to 33GHz) A33 = 0.047”(Up to 90GHz) Note: See individual drawings for operating frequency variants available. 21A-FPA Y(Max Frequency) N = Type-N(18GHz) S = SMA(27GHz) E = 3.5mm(32GHz) D = 2.92mm(40GHz) C= 2.4mm(50Ghz) B= 1.85mm(70GHz) P= SMP(40GHz) PM = SMPM(60GHz) Z 1 = Straight Male 2 = R/A Male 3 = Bulkhead Mount 4 = Panel Mount F = Straight Female R= R/A Female Sales@ConductRF.com - Tel: +1 978 374 6840 - YYY FYY = Length in ft.(F06 = 6ft) SYY = Length in in.(S18 = 18”) YMY = Length in M(2M5 = 2.5m) CYY = Length in CM(C50 = 50cm) www.ConductRF.com
FPA28C-PMRPMR-S24 价格&库存
很抱歉,暂时无法提供与“FPA28C-PMRPMR-S24”相匹配的价格&库存,您可以联系我们找货
